Kioti K 2510 lower radiador hose heater.
   / Kioti K 2510 lower radiador hose heater. #1
sneaky001
Lodi ohio
Kioti CK2510 / Allis Chalmers B
I bought a Kat's 600 watt Lower radiator hose heater for my Kioti ck 2510. My question is that on the package it says several times not to install on a tractor without a water pump bypass. Does my Kioti have a bypass on the waterpump? It says the heater is universal and work on all Kubotas, Yanmars, masseys and all compact tractors. It does not say anything about Kioti tractors. I'm assuming it's ok to use but before I cut my lower radiador hose I wanted to ask you guys first. Thanks.
   / Kioti K 2510 lower radiador hose heater. #2
My dealer installs block heaters on every Kioti that he sells. I have one, but have never used it, mostly because my DK-40 stays in a radiant heated floor barn bay and only sees extreme cold when out plowing, etc. Personally I wouldn't install a radiator hose heater. If the block is warm the tractor should start. Do you store yours outside in winter?
I store it inside in a non heated barn. I heard good things about the inline heater on this site, that's why I bought one.
   / Kioti K 2510 lower radiador hose heater. #4
When we lived in Alaska - that's all I ever used to keep my vehicles warm - - lower radiator hose heater. I think the bypass is so the water you heat with the little heater will BYPASS the radiator and circulate just thru the engine. Otherwise - the radiator will do its job and most all the heat generated by the hose heater would be lost in the radiator before reaching the engine.
OK, Thanks a lot. I'll put it on today.
   / Kioti K 2510 lower radiador hose heater. #6
Can I ask what size you bought was it the 1.5 inch.
   / Kioti K 2510 lower radiador hose heater. #7
I put one on back in 2015 (on my 2014) cuz it lived outside. I had it on a timer. I can't remember which I bought but it was a little smaller than the ID of the rubber hose. Instead of sending it back I used it and tightened the hose clamps well. Seems to be OK. Now my tractor is out of the elements but in an unheated garage. Since we are getting snow I plugged it and the battery maintainer in last night.
   / Kioti K 2510 lower radiador hose heater. #8
Can you post a picture of it please, there isn't a lot of room in there because of the exhaust pipe
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
2014 CATERPILLAR 279D SKID STEER (A51246)
2014 CATERPILLAR...
2007 International 4300 Box Truck, VIN # 1HTMMAAL07H360176 (A51572)
2007 International...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
New Holland B95 Backhoe (A50490)
New Holland B95...
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
