Rear Finish Mower Kioti Finish Mower question
   / Kioti Finish Mower question #1
jkmfarmer
Farmall C
Recently purchased a used 3 pt Kioti KRM03-60 finish mower. No manual. Internet says it's very similar to or the same as a WAC, 1st Choice, Simca and a couple others. Made in Italy. Going over the mower, I found the gearbox full to the top. I pulled the screw in dipstick and noticed it has 2 marks on it. The highest mark is about 1/2 way down the stick and the lower mark is about 3/4" lower. My best guess is that the oil level should be between the two marks on the stick or they wouldn't be there. I don't think the gearbox should be completely full. Looking for opinions. Thanks....jkm
   / Kioti Finish Mower question #2
personally would change the gear oil on a used machine, no telling how old & if there's moisture accumulation. suck out as much as you can. would use conventional GL5 gear oil (not fully synthetic) as it might compromise old seals, etc.
Valvoline makes a conventional 75/90. but not sure of the grade for your model, some may suggest 85/140. good luck
also insure the vent is working properly
   / Kioti Finish Mower question #3
Yes, between the 2 marks.
I have an 84" First Choice finish mower
That's what I'm in the middle of. Trying to determine how much oil goes in the gearbox. Internet says finish mower gearboxes hold from a few ounces to 2 qts depending on the mower. But nothing specifically about the Kioti. I'll probably just put enough in for the level to be between the marks.
DK - Thank you. That's the info I was looking for....jkm
JOHN DEERE 6135RW401 MOTOR (A51247)
JOHN DEERE...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A55314)
2019 New Holland...
2012 International 4300 Reefer Truck (A57024)
2012 International...
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
2018 JCB Truss Jib Telescopic Hydraulic Boom (A53421)
2018 JCB Truss Jib...
