Kioti DK6010 clunking
/ Kioti DK6010 clunking #23
Are you sure the loader brackets are all tight? I get clunking if i say…. Harrowing in the field with loader attached. I generally drop the loader when doing field work such as spraying, harrowing, etc.
/ Kioti DK6010 clunking #25
Did you double check the loader bracket bolts?
In fact, I would double check every bolt and pin I could find.
/ Kioti DK6010 clunking #26
One thing I do with my FEL attachment bolts is I apply Loctite to them and then torque to specification, just for insurance, I paint mark them so I can see if they have backed off at all. Do the same with the lug nuts on the wheels.
2016 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Truck (A61568)
2016 Globe Trailer...
2005 CHANDLER 500 BBL FRAC TANK (A60736)
2005 CHANDLER 500...
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
2006 JAYCO JAYFLIGHT 30' TYPE CAMPER (A58375)
2006 JAYCO...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
