Kioti DK5510 popping out of gear under load
   / Kioti DK5510 popping out of gear under load #1
bigmaccuda
Signal Mountain, TN
Kioti DK5510H
I have a Kioti DK5510 (2016 - 200 hours) that is popping out of gear (forward) when the tractor is underload or going up a hill. Has anyone experienced this issue?
Thanks,
Mike
   / Kioti DK5510 popping out of gear under load #2
Let's give you a bump, hopefully someone can be of more help than me.
   / Kioti DK5510 popping out of gear under load #4
Thanks,
Mike
Do you feel it getting all the way in gear? After a quick look on the service manual, looks like there is an adjustment on the shuttle shift linkage. Maybe it's worth a try.
Highly unlikely that is wear related with such low hours.
Appreciate the help my brother ...
It feels like it goes into gear ... and great suggestion .. I would LOVE it to be that simple. I talked to the dealer i purchased it from .. he was also surprised that it was happening with the low hours. He did say he had fixed one with a "similar" issue ... $1,200 - $1,500 ... yikes :)
Thanks,
Mike
   / Kioti DK5510 popping out of gear under load #7
There was an issue with the early DK40-50 range of tractors from mid 2000's that would break a small gear in the transmission if people tried to power shuttle them and would cause popping out of gear.
Thanks ... do you know if the gear can be "partially" broken? If I hold the gear shift I can keep it from pooping out.
Mike
   / Kioti DK5510 popping out of gear under load #9
The shuttle syncronizer gear will break in half and fall to the bottom of the transmission. The symptom was popping out of gear but could be held in gear by hand.
BINGO ... I suspect that is my problem ... THANKS Randy ... appreciate ALL the help.
Thanks,
Mike
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2018 Forest River Grey Wolf 26RR Lmtd Toy Hauler (A52384)
2018 Forest River...
2012 FORD F-250 XL SUPER DUTY (A52472)
2012 FORD F-250 XL...
Marliss Industries Grain and Soybean Drill - Selling ABSOLUTE NO RESERVE (A52748)
Marliss Industries...
