Front-End Loader Kioti DK55 Loader
/ Kioti DK55 Loader #1
htalllen
Brandon, Ms
2010 Kioti DK55
I have a 2010 DK55 Kioti with front end loader. The cable that lowers the boom broke where it attaches to the joystick and l can't lower the boom. Is there a relief valve for the hydraulics that I can use to lower the boom so that I can transport the tractor to the repair shop?
/ Kioti DK55 Loader #2
I would imagine you can trace the cable back to the valve block and manipulate the valve by hand to lower the loader. Or trace the hydraulic hoses from the loader back to the valve block. It's probably just below the floor board on the same side as the joy stick.
Is it under warranty? If not you might consider getting the cable and replacing it yourself. It should be fairly easy to do.
Edit... I see you've just arrived here. Welcome!
Four (4) Firestone Combine 520/85R42 Tires (A63116)
Four (4) Firestone...
GAS BOY DIESEL FUEL PUMP (A62131)
GAS BOY DIESEL...
40' CONTAINER (A62131)
Forklift Safety Basket (A61567)
Forklift Safety...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2002 Blue Bird F131612 Bus (A61568)
2002 Blue Bird...
