landdog49
- Joined
- Jun 9, 2006
- Messages
- 45
- Location
- Athens, TX
- Tractor
- Zetor 7441 Cab FEL, Kioti DK45SE HST Cab FEL
Does anyone have a problem with the engine overheating while running AC? If so have you solved it and how? I have a Kioti DK45SE HST Cab and KL401 loader. If I am bushhoging and the vegetation is over 6-10 inches tall and/or small parts break off they go to the screen in front of my radiator causing it to overheat. Sometime it only take an hour for the vegetation accumulation to cause it to overheat. Head pressure build up in the AC compressor causing the belts to squeal. The dealer says just blow or wash it out. Not an acceptable answer because it takes 10-15 minutes clean after I travel to a water hose or my shop. If I am baling hay there is no water hose or air.
