KIOTI DK4210 starter
/ KIOTI DK4210 starter #1
TedR82
KIOTI DK4210
Is there something that prevents a KIOTI DK4210 from starting? I can heard the started relay pick but starter doesn't turn.
/ KIOTI DK4210 starter #2
The battery most likely doesn't have enough juice. If it's a new battery check the connections
I have the same problem with a DK4210 with less than 6 hours. The battery is dead and I tried jumping with a good battery. The solenoid clicks but the starter doesn't turn. If I jump 12 volts to the starter it turns but very slow. Tractor doesn't start.
/ KIOTI DK4210 starter #4
Try checking to see how much voltage the starter is actually getting when you try to start. If it's not getting ten or eleven volts it may not go. If it's not getting the volts you need to backtrack to see why not.
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
2021 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A66736)
2021 Ram 1500...
2013 WACKER NEUSON LTN8 LIGHT PLANT (A68842)
2013 WACKER NEUSON...
16 FOOT TRASH TRAILER (A67714)
16 FOOT TRASH...
Turf Tiger Velocity Plus (A64557)
Turf Tiger...
