KIOTI DK4210 starter
/ KIOTI DK4210 starter #1
TedR82
KIOTI DK4210
Is there something that prevents a KIOTI DK4210 from starting? I can heard the started relay pick but starter doesn't turn.
/ KIOTI DK4210 starter #2
The battery most likely doesn't have enough juice. If it's a new battery check the connections
I have the same problem with a DK4210 with less than 6 hours. The battery is dead and I tried jumping with a good battery. The solenoid clicks but the starter doesn't turn. If I jump 12 volts to the starter it turns but very slow. Tractor doesn't start.
/ KIOTI DK4210 starter #4
Try checking to see how much voltage the starter is actually getting when you try to start. If it's not getting ten or eleven volts it may not go. If it's not getting the volts you need to backtrack to see why not.
KUBOTA M125X TRACTOR (A60430)
KUBOTA M125X...
UNUSED FUTURE FT15P EXCAVATOR (A60430)
UNUSED FUTURE...
2018 WANCO WTSV PORTABLE ARROW BOARD (A60430)
2018 WANCO WTSV...
More info coming soon! (A56858)
More info coming...
2022 Horizon (A55973)
2003 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A55745)
2003 UTILITY...
