Kioti DK40SE loader mount/subframe
   / Kioti DK40SE loader mount/subframe #1
WelshSam
Wales, UK
Landini 1.40 (Kioti/Daedong DK40SE)
Hi all. I'm newly registered here but have had lots of helpful advice from other people's threads over the years, so thanks for that.
I've got a Landini 1.40 which is the same as a Daedong/Kioti DK40SE. I've recently bought a suitable loader to fit which as far as I can tell matches the specs of the KL401 loader pretty well. The loader came without the mounting posts/subframe so I'm planning on fabricating my own.
I'd really appreciate if anyone could share some pictures of the arrangement of the loader mounts on their DK40SE, especially if they also have some dimensions for the steel sections of the upright posts, and the flat bars extending to the rear axle. I contacted a few loader manufacturers and although I think they have info on my tractor none were keen to share any info unless I bought a complete new loader including the mounting hardware, which unfortunately was at least 3x my budget. I'm sure I'm inclined to overbuild but I'd rather not add too much unnecessary weight if I can avoid it.
Sam
Here's a couple of pictures, not the best sorry.
   / Kioti DK40SE loader mount/subframe #3
I can't help, other than to give your thread a bump; that said, seeing a blue Kioti is pretty cool and I absolutely love your Rover!
   / Kioti DK40SE loader mount/subframe #4
They are not the simplest thing to make I assume, but I don't see why you can't avoid the angled round tubes and make it with heavy rectangle tubing?
Also compare cylinder sizes and angles to the Kioti loader. It lifts a lot and I assume it must be near the maximum of what the front axle and chassis can handle, so I wouldn't go for more lifting power and probably a bit less would be good for longevity.
Thanks Indylan, that's really helpful. Hard to find exploded diagrams on UK dealership websites.
Yeah that's a good point regarding overloading the front axle. I'm not too worried, I think the loader I've got is a little bit under spec when it comes to max lift, so I should be safe.
I'll avoid the angled round tube I think, but will try to stick to round tube as opposed to square because I think it's better at resisting torque? My loader requires a different style mount upright/pillar, so it will probably be something like 5x1" flat bar
   / Kioti DK40SE loader mount/subframe #6
When I built my loader, entirely from scratch, cylinders and everything, I just used the same rectangular tubing I used for the loader arms.
My mounts may look a bit different than most because I have mid mounted ROPS, so that made the base for the mount, pretty much. Anyway, I stacked 3 short pieces of the rectangular tubing together (probably overkill) and then the mount welds on those pieces.
In my case, I ran a support bar from the loader mount to the front of the tractor. This helps provide a better support overall and doesn't push so many forces and stresses in the center of the tractor. I'm not a fan that manufacturer went away with these.
I'll add some pictures just to give some more ideas. The entire build thread is here with lot more pictures: Homemade loader for Branson tractor
Oh, and don't forget the support bars that go under the tractor, from the loader mounts to the rear axle. Very important as well.
Thanks ptsg, that's a good thread. I know what you mean about the front support bar but I would prefer not to have one so that I can still easily remove side panels for servicing etc. What size bar did you use to link to the rear axle?
Also, how's your loader holding up? Looks like you did a great job on the build (y)
   / Kioti DK40SE loader mount/subframe #9
I used 80 mm C channel. That's what I had at the time. 80x15 mm flat bar would be a great choice too. Your tractor is pretty much the size of mine.
It's holding up great. I use it to load logs on the dump trailer with the forks, move dirt, tons of dirt. To be fair, it does sit a lot out of the tractor but when I need it, I really need it and gets used a lot.
About the only thing I would change now, was to use smaller bore cylinders. 50 mm instead of 60mm. When I built it, I tried to match, more or less, the capacities of the factory Branson loader. I really don't know why since I never push a loader to the max capacity, maybe 3/4 of the capacity at most. So the smaller cylinders would provide less lifting capacity (I'm good with that) but more speed, which I prefer.
   / Kioti DK40SE loader mount/subframe #10
I have a dk45se and the same loader I think its the same frame as the 40. If that would help I'd be glad to take some pictures for you. To be clear you are referring to where the loader frame mounts to the tractor? That it? You want pictures or dimensions of the metal (assuming its a hollow frame, never checked)?
Kivel 48in Pallet Fork Attachment (A49251)
Kivel 48in Pallet...
2013 Ford Focus SE Hatchback (A48082)
2013 Ford Focus SE...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A46683)
2025 Kivel 48in...
JMR 48in Dingo Grapple (A49251)
JMR 48in Dingo...
2007 Peterbilt 335 Mickey AO-A Battery Truck (A46683)
2007 Peterbilt 335...
2013 KENWORTH T800(INOPERABLE) (A48992)
2013 KENWORTH...
