Kioti DK40SE 3 Point Pin
   / Kioti DK40SE 3 Point Pin #1
ratnester
Kioti DK40SE HST
Are there any parts diagrams available for the DK40SE? Can't find much with google.
I lost the pin on the bottom of the 3 point last night. It's a stub pin with a 14mm bolt securing it. I wanted to get the part number and see if I can find one online. My closest dealer is an hour away.
   / Kioti DK40SE 3 Point Pin #2
Well apparently my workplace no longer likes tractors because I can't load the site, but Home Michigan Iron & Equipment Morrice, MI (855) 265-459 has an online parts catalog you should be able to find what you need there.
They also mail order kioti parts and I've purchased a few things from them and been very happy with their service.
Best of luck in your hunt.
Thanks N2DFire! I found the part number got one order. Appreciate the help!
   / Kioti DK40SE 3 Point Pin #5
Put some LocTite on the securing bolt. I was fortunate (rarity!) that when one of my pins popped out I found it laying just underneath the PTO shaft (held there by grass and such): no clue how long it had been out- I had been fighting my bush hog digging in all over the place but was in a hurry to get some mowing done; when driving up and turning on to a pathway I felt things weren't right- bush hog twisted up and jammed into one of the tires! I had to check with my dealer on the bolt size: told them that they should LocTite these bolts- how many people actually remove the link arms (vs the importance of keeping your arms attached!)?
air compressor (A55758)
air compressor...
CHANDLER 500 BBL FRAC TANK (A58214)
CHANDLER 500 BBL...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2017 CAT 315F LCR EXCAVATOR (A58214)
2017 CAT 315F LCR...
16001 (A55853)
16001 (A55853)
New/Unused Electric 3-Wheeler (A57453)
New/Unused...
