Kioti DK40SE 3 Point Pin
   / Kioti DK40SE 3 Point Pin #1
ratnester
Kioti DK40SE HST
Are there any parts diagrams available for the DK40SE? Can't find much with google.
I lost the pin on the bottom of the 3 point last night. It's a stub pin with a 14mm bolt securing it. I wanted to get the part number and see if I can find one online. My closest dealer is an hour away.
   / Kioti DK40SE 3 Point Pin #2
Well apparently my workplace no longer likes tractors because I can't load the site, but Home Michigan Iron & Equipment Morrice, MI (855) 265-459 has an online parts catalog you should be able to find what you need there.
They also mail order kioti parts and I've purchased a few things from them and been very happy with their service.
Best of luck in your hunt.
Thanks N2DFire! I found the part number got one order. Appreciate the help!
   / Kioti DK40SE 3 Point Pin #5
Put some LocTite on the securing bolt. I was fortunate (rarity!) that when one of my pins popped out I found it laying just underneath the PTO shaft (held there by grass and such): no clue how long it had been out- I had been fighting my bush hog digging in all over the place but was in a hurry to get some mowing done; when driving up and turning on to a pathway I felt things weren't right- bush hog twisted up and jammed into one of the tires! I had to check with my dealer on the bolt size: told them that they should LocTite these bolts- how many people actually remove the link arms (vs the importance of keeping your arms attached!)?
2020 DRAGON ESP...
Sterling AT (A55315)
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
2006 Dewatering and Drying Centrifuge (A56857)
2006 Dewatering...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
