kioti dk35 hydraulic lift keeps going down on fluid
   / kioti dk35 hydraulic lift keeps going down on fluid #1
weldonjr
kioti dk35
my rear lift will not raise , i check fluid and sure enough it is down , add fluis turn my shute lift starts working , I do not see no leaks . this is to use my snow blower. hoses appear ok , front bucket works just affecting rear lift
WHAT AREA SHOULD i LOOK FOR LEAKS
   / kioti dk35 hydraulic lift keeps going down on fluid #4
Check your engine oil level. On many tractors a leak at the shaft seal on the hydraulic pump will cause fluid to leak into the engine's crankcase. Your oil level will rise to the point of flowing out the dipstick hole. If left unchecked this can lead to catastrophic engine damage.
is it a big job to take that pump off ?
HOW WOULD IT GET TO THE ENGINE OIL COMPARTMENT ?
   / kioti dk35 hydraulic lift keeps going down on fluid #8
Did you read roadworthy post?
   / kioti dk35 hydraulic lift keeps going down on fluid #9
If fluid level is ok and front loader works fine you likely have a problem with a valve and not a fluid level issue.
And how is the chute rotation plumbed?
Pictures would also do wonders
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
2008 Ford F-450 Crew Cab Service Truck (A52377)
2008 Ford F-450...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A53472)
Kubota BX2680...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
UNUSED CFG QUICK ATTACH HYD POST DRIVER (A51248)
UNUSED CFG QUICK...
40' CONTAINER (A51244)
