kioti dk35 hydraulic lift keeps going down on fluid
   / kioti dk35 hydraulic lift keeps going down on fluid #1
weldonjr
kioti dk35
my rear lift will not raise , i check fluid and sure enough it is down , add fluis turn my shute lift starts working , I do not see no leaks . this is to use my snow blower. hoses appear ok , front bucket works just affecting rear lift
WHAT AREA SHOULD i LOOK FOR LEAKS
   / kioti dk35 hydraulic lift keeps going down on fluid #4
Check your engine oil level. On many tractors a leak at the shaft seal on the hydraulic pump will cause fluid to leak into the engine's crankcase. Your oil level will rise to the point of flowing out the dipstick hole. If left unchecked this can lead to catastrophic engine damage.
is it a big job to take that pump off ?
HOW WOULD IT GET TO THE ENGINE OIL COMPARTMENT ?
   / kioti dk35 hydraulic lift keeps going down on fluid #8
Did you read roadworthy post?
   / kioti dk35 hydraulic lift keeps going down on fluid #9
If fluid level is ok and front loader works fine you likely have a problem with a valve and not a fluid level issue.
And how is the chute rotation plumbed?
Pictures would also do wonders
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A53472)
2006 Magnolia Dry...
2019 MACK GR64F TANDEM AXLE CEMENT MIXER TRUCK (A52577)
2019 MACK GR64F...
1998 Blaw-Knox PF 150 Paver (A52384)
1998 Blaw-Knox PF...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
2020 FOR TRANSIT CONECT CARGO VAN (A52577)
2020 FOR TRANSIT...
2014 Chevrolet Silverado 4x4 Pickup Truck, VIN # 1GC1KXEG9EF156183 (A51572)
2014 Chevrolet...
