Kioti DK35 Fixed tachometer and hour meter
   / Kioti DK35 Fixed tachometer and hour meter #11
It depends on the end goal. If you really want originality, I don't think the parts are available to rebuild the existing one. New one's are available at a cost. If just counting the hours for maintenance, install an electric meter.
   / Kioti DK35 Fixed tachometer and hour meter #12
Thanks a million Jim, just purchased an electric hour meter for Amazon for $14. Great idea.
   / Kioti DK35 Fixed tachometer and hour meter #13
Vince,
I did some research and I believe you are correct. I would have never imagined a cable driven hour meter. I could not find any reference for the DK35 and saw in the Dealer brochure on the DK35se that the hour meter was electric.
So I performed an internet search on mechanical hour meters in tractors. I was actually amazed how they work. They are set-up as a counting mechanism. Over a certain RPM, like 1600, it basically counts gear teeth and converts them to an hour. However, below the set RPM, it assumes a partial hour. So these were referred to as RPM hours. The justification for this is that most tractors were run at an RPM for the PTO. As more tractors were used for other purposes, lower RPMs were common and the electric hour meter was necessary. So, if you have two tractor idling next to each other, one with the mechanical hour meter and one with the electric hour meter, the mechanical hour meter will show a lower count by the end of the day.
I believe most older tractor worked this way (cable operated)
My previous JD 850 had the same setup.
I believe around 2100 RPM for 1 hour equaled 1 hour on the meter on my JD and my Kioti
2020 MACK P164T (A58214)
2020 MACK P164T...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
2017 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Terex TLM40 Boom (A55302)
2017 RAM 5500...
2013 Heartland Elkridge 37UL 37ft. T/A 5th Wheel Travel Trailer (A55853)
2013 Heartland...
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
