Kioti DK35 Fixed tachometer and hour meter
   / Kioti DK35 Fixed tachometer and hour meter #11
It depends on the end goal. If you really want originality, I don't think the parts are available to rebuild the existing one. New one's are available at a cost. If just counting the hours for maintenance, install an electric meter.
   / Kioti DK35 Fixed tachometer and hour meter #12
Thanks a million Jim, just purchased an electric hour meter for Amazon for $14. Great idea.
   / Kioti DK35 Fixed tachometer and hour meter #13
Vince,
I did some research and I believe you are correct. I would have never imagined a cable driven hour meter. I could not find any reference for the DK35 and saw in the Dealer brochure on the DK35se that the hour meter was electric.
So I performed an internet search on mechanical hour meters in tractors. I was actually amazed how they work. They are set-up as a counting mechanism. Over a certain RPM, like 1600, it basically counts gear teeth and converts them to an hour. However, below the set RPM, it assumes a partial hour. So these were referred to as RPM hours. The justification for this is that most tractors were run at an RPM for the PTO. As more tractors were used for other purposes, lower RPMs were common and the electric hour meter was necessary. So, if you have two tractor idling next to each other, one with the mechanical hour meter and one with the electric hour meter, the mechanical hour meter will show a lower count by the end of the day.
I believe most older tractor worked this way (cable operated)
My previous JD 850 had the same setup.
I believe around 2100 RPM for 1 hour equaled 1 hour on the meter on my JD and my Kioti
2012 Ford F-550 Crew Cab SWAT Transport Truck (A55852)
2012 Ford F-550...
14179 (A55788)
14179 (A55788)
JOHN DEERE 6135RW401 MOTOR (A51247)
JOHN DEERE...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
2016 CATERPILLAR 325FL CR EXCAVATOR (A52705)
2016 CATERPILLAR...
