Kioti DK 35 charging problem
   / Kioti DK 35 charging problem #1
joecim
Glasco, NY
Kiori, DK-35
I purchased a new alternator and this has not solved the problem. I have 12v at the main power post on the alternator, there is 12v applied to the red wire when I turn on the key. Looking at the diagram, the second red/striped wire appears to go through the diode and through the dash light. Not sure what reading I'm suppose to get there or if the wire harness might be at fault. I see no damage and the fuse is good. Any ideas????
Thanks
Joe
   / Kioti DK 35 charging problem #2
Thanks
Joe
Welcome to TBN, Repost this in the Kioti forum and the guy's will jump on it I'm sure.
Thanks for the welcome. I will have to look through the site a little better so I can follow your suggestion.
Thanks. Is it as cold and snowy there as it is here?
   / Kioti DK 35 charging problem #6
:cool:I know that from other members on this site an ignition switch problem sent me and my Kioti DK90 away from the altenator to the igntion switch. shot of WD40 in the keyhole while cycling the switch on and off without depressing the clutch cured the problem. This is a great site with helpfull members. A great thing about help. Pass it on. Something so trivial could save a member from the dealer wolves.:eek:
   / Kioti DK 35 charging problem #7
:cool:You don't know for snow. It's snowed so bad this year, I started reading the bible. lol:eek:
I did check to see if I was getting the 12v at the alternator when the key switch was turned to the start and then run position, that was good. I will try your squirt of wd-40
2019 Allmand Light tower (A49461)
2019 Allmand Light...
John Deere Riding Mower (A50860)
John Deere Riding...
Headache Rack (A50860)
2014 Brent 1596T Dual Auger Grain Cart (A50657)
2014 Brent 1596T...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
10x16.5 Tire Assembly (A51039)
10x16.5 Tire...
