Kioti Dark Gray Paint
/ Kioti Dark Gray Paint #11
actually i just purchased a can of spray paint from my dealer for mine.
/ Kioti Dark Gray Paint #13
Nobody else tried this?
I have the same tractor and wanted to match the color on the bucket. For the base I used Rustoleum gloss charcoal grey and added some Rustoleum white to it. I had Rustoleum black in case I went too far. It did not take much white to get very close IIRC. I applied it to the rear of the bucket and was happy with the final match. For what it's worth, Toukow
Thanks - what kind of ratio? What size can? I was leaning towards the rattle can charcoal but the touch of white is interesting.
/ Kioti Dark Gray Paint #15
Take a small painted part off your tractor, and take that part to any paint store.
They will be able to computer match/make your color with a quart of industrial enamel.
I just went to my local Sherwin Williams store, for a match to Kubota dark gray.
$26 + tax for a quart of exact match equipment enamel.
/ Kioti Dark Gray Paint #16
First, I somehow missed many of the responses to your question so this may have been redundant. Second, I was actually trying to match the front end loader which is lighter than the tractor itself I believe. I have spray equipment, but if a rattle can matches that seems the way to go, or having a paint shop match as mentioned if you're picky. I started out 10:1 ratio, but that's an approximation.
Mower King Brush Cutter (A53317)
Mower King Brush...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
KUBOTA M9000 UTILITY SPECIAL TRACTOR (A59823)
KUBOTA M9000...
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
2020 Hino Garbage Truck (A60352)
2020 Hino Garbage...
