Kioti CK3510H (2017) Injection Nozzles
   / Kioti CK3510H (2017) Injection Nozzles #1
Muskrat Mower
2017 Kioti CK3510
Due to contaminated fuel, I need to replace all 3 injectors. OEMs are about $900 each. I had the same issue with the IMV valve and was able to find an inexpensive replacement. Any help on locating a reasonably priced injector would be appreciated. Thanks in advance.
   / Kioti CK3510H (2017) Injection Nozzles #2
If you are able to source Injectors aftermarket, make sure you have a KIOTI Dealer install the Injectors. The dealer will need to reprogram the ECU for each new Injector Code BEFORE the Injectors are changed out.
Hope this helps
   / Kioti CK3510H (2017) Injection Nozzles #3
Wait, what?! $900 each? I just looked up mine and they are $120 each.
Is that just because it's common rail? Holy cow
   / Kioti CK3510H (2017) Injection Nozzles #4
Cheapest I found was $650.00.!!!
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
GENERATOR HOUSE POEWERED BY TWIN 550HP (60 SERIES)  DETROIT 14.0L ENGINES (A50854)
GENERATOR HOUSE...
2025 K3325 UNUSED Double Garage Steel Barn (A50860)
2025 K3325 UNUSED...
2013 Chevrolet Impala Sedan (A48082)
2013 Chevrolet...
2007 CHEVROLET SILVERADO 4X4  DUALLY TRUCK (A51222)
2007 CHEVROLET...
