Kioti CK3510H (2017) Injection Nozzles
   / Kioti CK3510H (2017) Injection Nozzles #1
Muskrat Mower
2017 Kioti CK3510
Due to contaminated fuel, I need to replace all 3 injectors. OEMs are about $900 each. I had the same issue with the IMV valve and was able to find an inexpensive replacement. Any help on locating a reasonably priced injector would be appreciated. Thanks in advance.
   / Kioti CK3510H (2017) Injection Nozzles #2
If you are able to source Injectors aftermarket, make sure you have a KIOTI Dealer install the Injectors. The dealer will need to reprogram the ECU for each new Injector Code BEFORE the Injectors are changed out.
Hope this helps
   / Kioti CK3510H (2017) Injection Nozzles #3
Wait, what?! $900 each? I just looked up mine and they are $120 each.
Is that just because it's common rail? Holy cow
   / Kioti CK3510H (2017) Injection Nozzles #4
Cheapest I found was $650.00.!!!
2014 Therm Dynamics TD400 Towable Flameless Heater Trailer (A49461)
2014 Therm...
2013 John Deere 4730 Self-Propelled Sprayer (A51039)
2013 John Deere...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2020 John Deere 870GP Articulated Motor Grader (A49461)
2020 John Deere...
Off-Road Buggy (A50860)
Off-Road Buggy...
2005 Ford Freestar SE Van (A48082)
2005 Ford Freestar...
