kioti ck3510 with smoking problem
   / kioti ck3510 with smoking problem #11
Got my ck3510 back from dealer the engineers had adjust timing and ecu so it takes our diesel Korea does not use ethanol in theirs
I didn't know our Diesel fuel had ethanol in it!
   / kioti ck3510 with smoking problem #12
HI guys (used generically :)) .... My first post. I am getting a CK3510 on Saturday. Do I need to get some kind of fuel additive for the tractor?
Thanks,
Mike
   / kioti ck3510 with smoking problem #13
Update on my CK27. Took it to the dealer and they found a bad fuel injector. Tractor ran better after replacing all 3 ( I elected to replace all 3 ) but still wasn't right. Compression check showed #3 cylinder bad at 80%. They pulled the head and found the #3 piston rod bent...this was due to the fuel injector leaking which caused a hydrolock on #3. New rod on order should be getting the tractor back early next week. I have 250 hrs on it.
   / kioti ck3510 with smoking problem #14
Thanks,
Mike
I am going to start putting HOWSE fuel lubricate in mine. It is a good brand to use. Use it year round.
2022 Down2Earth 82in x 36ft Two-Car Hauler (A52128)
2022 Down2Earth...
2019 TOYOTA 8FGCU25 PROPANE FORKLIFT (A51222)
2019 TOYOTA...
Blue-Jet Liquid Fertilizer Applicator (A51039)
Blue-Jet Liquid...
2017 Ford F-250 Ext. Cab Pickup Truck (A50323)
2017 Ford F-250...
2018 Nissan Sentra Sedan (A50324)
2018 Nissan Sentra...
2020 Kubota Sidekick RTV-XG850 (A47384)
2020 Kubota...
