kioti ck3510 with smoking problem
   / kioti ck3510 with smoking problem #11
Got my ck3510 back from dealer the engineers had adjust timing and ecu so it takes our diesel Korea does not use ethanol in theirs
I didn't know our Diesel fuel had ethanol in it!
   / kioti ck3510 with smoking problem #12
HI guys (used generically :)) .... My first post. I am getting a CK3510 on Saturday. Do I need to get some kind of fuel additive for the tractor?
Thanks,
Mike
   / kioti ck3510 with smoking problem #13
Update on my CK27. Took it to the dealer and they found a bad fuel injector. Tractor ran better after replacing all 3 ( I elected to replace all 3 ) but still wasn't right. Compression check showed #3 cylinder bad at 80%. They pulled the head and found the #3 piston rod bent...this was due to the fuel injector leaking which caused a hydrolock on #3. New rod on order should be getting the tractor back early next week. I have 250 hrs on it.
   / kioti ck3510 with smoking problem #14
Thanks,
Mike
I am going to start putting HOWSE fuel lubricate in mine. It is a good brand to use. Use it year round.
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A52128)
Texas Post Driver...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2008 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2008 CATERPILLAR...
2013 Chevrolet Cruze LS Sedan (A50324)
2013 Chevrolet...
2009 GREAT DANE 53FT REEFER TRAILER (A52141)
2009 GREAT DANE...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
