Kioti CK30 loader
/ Kioti CK30 loader #1
alpacastarter
I am looking at a Kioti CK30 tractor. Unfortunately, under a load, the loader starts to come down. Without a load, it drifts down a little bit.
Any ideas on what the causes are and approximate cost to fix?
/ Kioti CK30 loader #2
Sounds like leaking cylinders or valve. Another possibility, joystick if it has linkages it maybe need adjustment, possibly holding valve slightly out of center.
/ Kioti CK30 loader
Thanks for the information. I'll check to see if there is a joystick adjustment.
Any idea how much it would cost to work on leaking cylinder or valve? Trying to get an estimate to see if I can negotiate that into the price.
/ Kioti CK30 loader #4
How fast does it leakdown is the question?...most all CUT loaders leakdown over time...JD even publishes a "acceptable leakdown" specification chart on their loaders they show you if your complain about it while under warranty.
/ Kioti CK30 loader #5
As far as costs, depends how proud they are of work they do. Can very greatly. My opinion is get price quotes in your area.
/ Kioti CK30 loader #6
Another thought as Kennyd posted, will it leak down bad enough for what amount of use of tractor? My 8n Ford leaks down and or out, but I have no desire at this point to fix it for what I use it for.
2016 CATERPILLAR 926M WHEEL LOADER (A65053)
2016 CATERPILLAR...
213141 (A64276)
213141 (A64276)
2018 SolarTech Silent Messenger Towable Solar Message Board (A64553)
2018 SolarTech...
1999 Van Hool Transit Bus T2100 Bus, VIN # YE2TC63B3X2043319 (A65563)
1999 Van Hool...
2023 J&J TRAILER (A65643)
2023 J&J TRAILER...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A64279)
2016 CATERPILLAR...
