Kioti CK30 Kubota 3030HSDC
/ Kioti CK30 Kubota 3030HSDC #21
72" is actually easier because you can drive right over it. I have a 60" so I have to raise the front end which is easily done with the fel. One of the rear casters is turned and locked in place so with the front 2 casters you can roll the unit around. I didn't like that so I welded up a dolly that slides under the rear of the deck giving me swivel wheels on all 4 corners so it is very simple for me to roll the deck anywhere. Drive shaft is a simple snap coupling, front mount is a lever that the front bar mounts into and rear is 2 spring loaded pins. Have the dealer show you; it's simple and strudy. The other nice thing about the mmm is the edge of the deck is very visible from the cab when you're trimming. Again, if I was brush cutting I'd want it on the 3pt for the reason you stated but for reg. mowing, I like underneath.
/ Kioti CK30 Kubota 3030HSDC #22
Munchie: see you're getting a blower also. I welded up the same kind of dollies for the carrier and front blower and it makes that job a no brainer too.
Thx forester...good info
BOX BLADE (A58214)
BOX BLADE (A58214)
John Deere 5090GN (A60462)
John Deere 5090GN...
2004 Ford F-250 Ext. Cab Service Truck w/ Liftgate (A59230)
2004 Ford F-250...
Club Car 4x4 Diesel Utility Cart (A59228)
Club Car 4x4...
2017 BX2680 Sub Compact Utility Tractor (A61306)
2017 BX2680 Sub...
2015 John Deere Z950M 72in Zero Turn Mower (A59228)
2015 John Deere...
