Kioti ck 3510 main fuses
   / Kioti ck 3510 main fuses #1
leegersch
Looking for help on the slo blow 60 amp fuses on a six year old kioti ck3610. Thanks for the earlier advice. I finally found two fuses right before me on a bracket mounted above and just behind the radiator and protected by a hinged enclosure. They really don’t want to come out, though I don’t see that there is anything on the fuse that could serve as a latch. My dealership is on vacation till August 10, of course. Should I just pull harder?
Thanks again, Lee
Thanks again, Lee
Turns out that the four electrical leads involved each terminate in a circular crimp. Each crimp is attached to a hole in one leg of its fuse with a small stainless steel bolt. You access those by opening the hinged sides of the plastic enclosure. Probably much more secure than the old push in fuses, but a lot more work to change. There is one 60 amp fuse for the battery and one for the preheat. Took me a while to realize the sides were hinged. Impossible to access the bolts otherwise.
   / Kioti ck 3510 main fuses #5
Should help someone else if they search. Thank you.
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
1999 TRAILMOBILE DRYVAN (A53843)
1999 TRAILMOBILE...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A53473)
2022 MAXXD BD14...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
255/70/22.5 TIRES (A53843)
255/70/22.5 TIRES...
