Kioti ck 3510 main fuses
/ Kioti ck 3510 main fuses #1
leegersch
Looking for help on the slo blow 60 amp fuses on a six year old kioti ck3610. Thanks for the earlier advice. I finally found two fuses right before me on a bracket mounted above and just behind the radiator and protected by a hinged enclosure. They really don’t want to come out, though I don’t see that there is anything on the fuse that could serve as a latch. My dealership is on vacation till August 10, of course. Should I just pull harder?
Thanks again, Lee
Thanks again, Lee
Turns out that the four electrical leads involved each terminate in a circular crimp. Each crimp is attached to a hole in one leg of its fuse with a small stainless steel bolt. You access those by opening the hinged sides of the plastic enclosure. Probably much more secure than the old push in fuses, but a lot more work to change. There is one 60 amp fuse for the battery and one for the preheat. Took me a while to realize the sides were hinged. Impossible to access the bolts otherwise.
/ Kioti ck 3510 main fuses #5
Should help someone else if they search. Thank you.
SWITCH HITCH HYDRAULIC HAMMER ATTACHMENT (A60736)
SWITCH HITCH...
2015 C.GALLEGOS PNEUMATIC TRAILER (A60736)
2015 C.GALLEGOS...
2006 Mercedes-Benz Unimog 405 4x4 Flatbed Truck (A56858)
2006 Mercedes-Benz...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
