Kioti Broken in Half
   / Kioti Broken in Half #291
There have been a great many discussions about ballast and it's effects on the front axle over the years.
And alot of what is being said....like "ballast always lightens the load on the front"....has to be understood with some context.
I'll use my MX for example cause I am familiar with what it weighs.
I can say first hand that a 500# ballast (along with my loaded tires and wheel weights) is NOT enough to keep the rear planted.
So...without ballast.....I might be able to pallet forks a tote with 75 gallons and the rears lift. (Let's say tractor weighs 6k. So now I have 6k + 75 gallons of weight ALL on the front.
Add rear ballast of 500#....now tractor weighs 6.5k.
Lifting the SAME 75 gallons is gonna put less weight up front
However....with ballast I might now be able to pick 125 gallons before tears lift
Now I have increased front axle load to 6.5k +125 gallons. Which is significantly more than no ballast where it could only lift 6k+75 gal.
So again ...it's all in context of what is being done.
With ballast gives you the ability to lift more up front. And that gives the ability to increase front axle load.
But if you are simply talking about a fixed load up front. (moving pallets or round bales) adding counter weight will Always reduce front axle load with the same given loader load.
The absolute worst case scenario is just enough ballast to max out the loader....but leaving near 0 weight on the rears. Because that is max loader lift...plus max tractor weight all on the front axle.
I use rear tire fluid, cast iron rear wheel weights and a 1,200lb BB on the 3pt. I must use mature caution when using my Grapple. :)
   / Kioti Broken in Half #292
And I have gone the other way, I use wheel weights, no fluid and no rear ballast.
If I can't lift it without the wheels getting light it's time for a different approach,
but my tractor is not a CUT I have lifted 3600# mafia blocks with her, very carefully.
   / Kioti Broken in Half #293
That looks like a massive overload issue or a really big bounce up in the air and a crash down. My guess is that the main bolts holding the machine together were loose and finally let go. Frame fatigue or just a faulty frame. That should still be under warranty? Looking again at the frame break looks like it snapped off right where it was welded to the front section. I emailed him out of curiosity.
   / Kioti Broken in Half #294
I did get a reply from the owner. Out of Warranty. The frame is not considered part of the drivetrain. Insurance company deemed failure due to material defect. The loader is rated for 3600 pounds. The frame break is not at a weld.
   / Kioti Broken in Half #295
Ugh, if that is true
Fix the frame and claim warranty on rest of drivetrain, lol
I’m sure the truth is somewhere in between
   / Kioti Broken in Half #296
The owner told me that Kioti has not returned any of his calls. Same goes for his dealer who also called Kioti.
   / Kioti Broken in Half #297
That's to be expected.
Somewhere in the almost 300 posts on this thread, someone mentioned that the guy used to constantly brag on social media about how he abused his tractor. Then the mechanic from his dealer called him out on that and denied any warranty claims.
EDIT: It's post #167: Kioti Broken in Half
"The guy that did is was using the tractor instead of a bulldozer or skidder. His dealer and local mechanic both told him he was crazy and would probably break something but he decided to destroy the tractor anyway! He's posted it on Facebook with several different stories including the some of them about how he high-centered it on a rock, his wife drove into a tree, and the one he got made fun of the most on his how he babied the tractor since new. His local mechanic showed up on that post and called him out!! lol:eek:😂"
   / Kioti Broken in Half #298
The truth finally came out. I guess it was a matter of more money than brains.
   / Kioti Broken in Half #299
It is not uncommon these days. My neighbor cracked a new 75HP New Holland in half while mowing. He hit a ditch at a nice clip and cracked it just like the picture here. he is very hard on equipment. Smaller tractors have become less structurally sound due to price competitiveness. New Holland, Deere, Kubota etc. have had to cheapen their products over the past twenty years to compete with cheap brands.
I looked at New Hollands when I was looking for a new tractor. I got under one and said, not for me. The Kioti and Mahindra tractors were made a lot heavier and rugged.
   / Kioti Broken in Half #300
Easier on drivetrain possibly, but the issue appears to be structural, my reference to the grapple was that it's oversized for the tractor which could possibly mean the owner wasn't easy on it. But who knows, maybe he was just transporting it or something else, hard to judge from just a picture.
Sent from my SM-G715U1 using TractorByNet mobile app
Regardless of the size of the grapple. The OP told me that the loader was rated for 3600 pounds. That 3600 pounds also includes the weight of the grapple. Usually the max loader weight is measured at the lift pins.
2013John Deere 244J (A47477)
2013John Deere...
Red Military Truck (A53422)
Red Military Truck...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
2012 Dodge Journey SUV (A53424)
2012 Dodge Journey...
CAT Skid Steer (A50322)
CAT Skid Steer...
