ovrszd
Epic Contributor
- Joined
- May 27, 2006
- Messages
- 32,244
- Location
- Missouri
- Tractor
- Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
This is a common debate.I don't recall much talk about ballast here. If the owner was using that monstrous grapple to the limit, traversing rough ground and had no ballast (or tire ballast which would not help here), the majority of the weight of the tractor and load was on the front axle and transferred through those sections of the frame. While the loader might have lifted the weight, the impact loads of traversing were likely too much. Could proper ballast have helped? I think theoretically, yes.
And if I were a Kioti rep - that's where I would go first.
If the FEL can't lift the load without the rear tires coming off the ground, adding ballast actually increases the load on the tractor front end until the rear tires return to the ground, then it begins to decrease the load on the tractor front end and increase the stress on the tractor chassis.
