Kioti Broken in Half
   / Kioti Broken in Half #171
Tough to tell from the pics, but it almost looked to me that the frame had been previously welded where it broke in half.
Not sure, but the frame at the point of separation is far less structurally sound than about 2' back.
That kind of looks cut. Maybe disgruntled spouse....
   / Kioti Broken in Half #172
i had a dozer quite a while ago that had a repaired cracked frame. it is not too hard to do considering the amount of leverage that is constantly put on a frame.
   / Kioti Broken in Half #173
That should not have happened on any tractor.
   / Kioti Broken in Half #174
>That's true but the ad is from Belgrade, Maine.
Not for nothing do we New Hampshiremen call them Maniacs.
   / Kioti Broken in Half #175
Looking back through PTSG's Pics
Not absolutely sure but, It appears that the op had no counterweight on the rear of the tractor. In this case that might be a good thing.
if the FEL is strong enough and the tractor op say, starts trying to pry out a 10 foot diameter boulder that only a bit is above ground with that long tine grapple and manages to get the rear tires off the ground it would have concentrated even more force on that front sub-frame, front axle and bearings.
What most guys don’t know and will find out later is overloading the tractor/loader will likely result in future front axle bearings & seal failure.
It t took me a while to learn that when digging with most FELs once you release the bucket/lift valves to a neutral position, there really isn't any safety PRV in the system- other than bursting a hose, blowing a seal or something more expensive Giving. I was lucky and in a couple cases popped a hose and in the other the seals failed.
Like Hay Dude says, in addition once those ball bearings are free from the destroyed cage that "used" to keep them in the race, they are now free to roam and show those weak kneed gear teeth just how much stronger 52100 chrome steel bearing material is.
   / Kioti Broken in Half #176
Here's not something you see every day. Browsing facebook and saw this.
Not sure what the backstory is.
Not worth $32K in that condition.
   / Kioti Broken in Half #177
Like Hay Dude says, in addition once those ball bearings are free from the destroyed cage that used to keep them in the race, they are now free to roam and show those weak gear teeth just how much stronger 52100 chrome steel bearing material is.
The way the tractor broke seems opposite of what would happen with too much weight in the FEL. It would bend upward in the middle.
   / Kioti Broken in Half #178
Here at TBN, a World fat with SCUTs, CUTs and Utility tractors, most with FELs, front axle/bearing failure is very rare. Definitely more rare than bent/broken FELs. Probably more rare than broken tractor chassis.
   / Kioti Broken in Half #179
If it had "bent" and stayed intact you would see upward bend in the middle. In this case, it broke completely apart. Gravity took over and it fell to the ground in the middle.
Metal Transport Rack (A59228)
Metal Transport...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A56438)
LIKE NEW 2023...
For Sale, Shrink Wrap Kit for implements, tractors, boats etc.
For Sale, Shrink...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
JOHN DEERE 330G SKID LOADER (A58214)
JOHN DEERE 330G...
