Kioti Backhoe
/ Kioti Backhoe #1
jssihs
Lanse, MI
Kioti RX7320 PowerShuttle
hi. will a kioti backhoe (2485) fit on a New Holland tractor? I plan on selling my nx6010 and getting a New Holland t4.75. thanks for the input. john.
/ Kioti Backhoe #2
Depending on how good your fabrication skills are I think you could make a set of mounts to catch your current subframe. I would keep all the mounts that are bolted to your current tractor. The best would be if you could check out how the new holland back hoe bolts on.
/ Kioti Backhoe
thanks. that is a good suggestion. :dance1:
20ft Bi-Parting Gates (A65583)
20ft Bi-Parting...
New/Unused Heavy Duty Plate Compactor (A65583)
New/Unused Heavy...
2014 Freightliner 122SD Day Cab Truck, VIN # 3AKJGNDR4EDFL0990 (A65563)
2014 Freightliner...
2021 Wacker Neuson G25 Quiet Power 20kW Towable Generator (A64553)
2021 Wacker Neuson...
2018 SKYJACK SJ1056 TELEHANDLER (A65643)
2018 SKYJACK...
250 Gallon Diesel Fuel Tank w/ Pump (A64047)
250 Gallon Diesel...
