Kioti backhoe Subframe and Housing Cracks
   / Kioti backhoe Subframe and Housing Cracks #11
My KB2485 backhoe subframe cracked and broke the rear housing for the hoe as well. I had it 20mo's and not sure when it happened but the cracks are catastrophic total failure. My dealer told me it was out of warranty (older than 1 year) but Kioti acknowledges bad welds on their sub frames and they went good for the entire repair (good on them) I'm guessing it would have been around $1500 CAD for a total dealer repair. I've also heard of instances where others have had a subframe crack and Kioti was not willing to help out at all. Just a heads up, inspect your subframe each time you remove it.
Can I ask what you have been digging with they backhoe?
   / Kioti backhoe Subframe and Housing Cracks #12
Exactly, that's where the load needs to be as close to the rear tires as possible. As you know a backhoe makes a lot of things move and twist.
Sure! I dug about 1000 feet of 3 to 4 feet deep french drain to remove water from a property I bought. I dug out about 30-40 stumps, replaced 3 or 4 Culverts on driveways for friends, got stuck in mud a few times and had to dig myself out (as long as you have a hoe your never really stuck :cool:). soil has alot of clay in it so that doesn't help either. I keep it on all the time, it's head and shoulders better then my other attachments for adding ballast, weight and stability to the machine - so it's my most used attachment. I do use it alot, but that's why it costs so much I guess - Hope this helps
   / Kioti backhoe Subframe and Housing Cracks #15
There have been several reports of bad welds on Kioti 3-pts as well. And I don't weld. figures
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2008 Ford F-350 Pickup Truck (A55852)
2008 Ford F-350...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
UNVERFERTH 210 (A53084)
UNVERFERTH 210...
