Kioti Axle
/ Kioti Axle #1
GRMC
Kioti LB2204
I have a Kioti LB2204 and broke the right front axle. Was told a axle from a Kubota L245 would fit. Can anybody conform it will?
/ Kioti Axle #2
I don't know if that the case and if you have availability to one it's certainly worth looking at but, if we are talking dollar for dollar I would get the Kioti part.
/ Kioti Axle
I checked with the Kioti parts department near me and was told they are no longer available.
Still looking and hoping to find one at a tractor salvage yard.
I can get one for the L245 from eBay.
/ Kioti Axle #4
You can try this place:
If they don't have one, maybe they can point you in the right direction.
/ Kioti Axle #5
I never could find a replacement for the axle on my Iseki TU1700F. Ended up buying a cheap wire feed welder and welding it back together.
Turned it on my lathe after welding. It works just fine. If you do this search Youtube on how to repair a broken axle. Several good video's out of India.
/ Kioti Axle
I found an original parts manual for my Kioti LB2204 on line. Once I received the manual I put the part number in the search it came up as
a Kubota L245. I found 3 used ones on eBay. I have put it back together and have used it a couple of times with no problems.
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
30ft Highway Trailer Co. Lowboy (A63118)
30ft Highway...
2016 Volvo Semi Truck (A66285)
2016 Volvo Semi...
2021 PETERBILT 367 (A65643)
2021 PETERBILT 367...
