Kioti 1914 Hydraulis
   / Kioti 1914 Hydraulis #1
dannyjkelly
I can't find any info on connecting the Log Splitter
I don't know is the hydraulic a closed or open system??
   / Kioti 1914 Hydraulis #2
I am far from the expert here, but on my ck20s it is an open system so that when the directional control lever is in neutral, the hydraulic fluids are being returned to the reservoir. Normally, A is the input and B is the outlet, although you can reverse the flow with the directional switch. I have yet to figure out why one would want to reverse the flow, but as I said I am no expert in this field. This continuous displacement pump is the reason you want to avoid like the plague, putting the rear hydraulics in gear without there being an implement or bypass hose in place. The pump will overheat and be destroyed.
   / Kioti 1914 Hydraulis #3
Please let us know if you have the front loader on the tractor or not. There is a hydraulic block on the tractor for auxiliary hydrualics. We can help you with the remote hydraulics. It would also be helpful to have the serial number of the tractor.
WOW thanks~ My 1914 has a Bush Hog 1846Qt, the joy stick has three hydraulic lines with quick disconnects. They tie into the OEM 'OIL PRESSURE RELIEF ASSEMBLY"
I'm getting a RamsSplitter system to hook up to the system.
My first thought was to use the disconnects to pressure port and tank port.
on the FEL.
Can I just leave Power beyond alone?
OR
should I tee the fitting at the auxillary valve.
I would run quick disconnects on the back of the Kioti
I tried to read the serial number...oh boy It is a 99 or 2000 model
maybe in bright daylight I can see it:):):)
I can email pictures of the valve & lines,
On the serial number
(Man !! they use small stamps)
it is 6040-00304
Here are two views, Hopefully it is a common hook up on tractors!
   / Kioti 1914 Hydraulis #7
Great information. Now a couple questions,
Does the Logsplitter have it's own control valve?
Is it an open center valve?
Did you want to add remote plugs to the back of the tractor?
Please let us know. You have a few options for setting up your hydraulics.
:rolleyes:According to Ramsplitter Log Splitter this is their answer:
Control valve automatically returns to start position after log has been split /// use your existing tractor for driving the hydraulics. Just hook up to the auxiliary outputs of your tractor and you are ready to use this log splitter
I don't have the splitter here yet. Should be in the next few days
I guess if it would work, the quickess would be to add two lines with quick disconnects. From the log splitter to the existing lines going to the FEL.
Just disconnect FEL when I use splitter
I also thought about using pipe "tee" from pressure/return side and took FEL/Log SPlitter line there.
Stop in rear with disconnect
What bothers me ...it sounds too easy:eek:
If we can figure out what fittings & lines I need, Do you sell the items also?
2015 Ford F750 Reel Loader Truck (A52377)
2015 Ford F750...
2021 CATERPILLAR CB2.7 DBL DRUM ROLLER (A52705)
2021 CATERPILLAR...
2017 Chevrolet Tahoe SUV (A52377)
2017 Chevrolet...
Ford Super Duty Pickup Truck Bed (A52377)
Ford Super Duty...
CAT CS563 (A47477)
CAT CS563 (A47477)
2017 Mitsubishi Outlander (A53424)
2017 Mitsubishi...
