Kioti 1914 Hydraulis
   / Kioti 1914 Hydraulis #11
Danny,
The simple hook-up is as follows:
Power beyond from the Loader Valve to the "in" port of the log splitter valve.
"out" from the log splitter valve to the tank port on the tractor block.
You will loose function of the 3-point hitch by doing this. There is a way to keep all of your tractor functions, but it would require adding some tees to the system, which would be our recommendation. Let us know if you would like a circuit with the tees so all tractor functions remain operational. Again, this would be our recommendation.
Yes, we carry all types of quick connectors. Because it is an aftermarket loader, we would want you to verify the numbers on the quick connects. We could let you know how much they would be. If you want to go with the tee system, we could put together a kit with all the fittings you would need and a circuit diagram for you to follow.
Hope this helps.
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2020 DRAGON ESP...
2000 GMC C7500 ANCHOR DRILLING TRUCK (A58214)
2000 GMC C7500...
LOT: (8) Chain Binders (A59076)
LOT: (8) Chain...
2019 Kubota RTV-X1140 4x4 Diesel Utility Cart (A56857)
2019 Kubota...
Terms & Conditions of (Buying through EquipmentDealz Auction) Final (A59213)
Terms & Conditions...
