kioti 1714 loader issues
/ kioti 1714 loader issues #1
devypower
kalamazoo mi
bolens h1704, john deere 400 with loader, kioti 1914 with loader, 1960's international utility 330 loader/backhoe
ok he it goes sorry if im a pain in the a** but i have an issue that has me puzzled beyond sanity, i posted a few months ago about a kubota swap in a kioti lb1914 that went south pretty quick lol, so i found a kioti lb1714 high hours but garage kept so very clean so the saga begins.... got the 1714 home swapped the loader over from the 1914 to the 1714 these are almost identical machines only visual differences, loader went on great but when i hooked up the hydraulics not so good visually the hydraulic block looks the same but as soon as i tried to use it, nothing i mean nothing the 3 point even quit working right. it goes down with the lever but goes up with loader control anyone know how to plum in a loader to these machines i have searched multiple sites even left one because they were all acting like im stupid for not knowing, pictures would be great
/ kioti 1714 loader issues #2
The Loader will plumb to the hydraulic block exactly the same as it came off the LB1914. Then you need to turn the valve on the block 90 degrees to open the Power Beyond flow to the attachment. Just remember to turn the valve back off if you ever remove the plumbing for the loader valve. You will not have hydraulic power to the loader until you turn the valve on. Look at the hydraulic block from the 1914 you removed the loader from. Turn the valve on the 1714 the same way.
Hope this helps
thanks for quick reply, i did put it the exact same way like 7 times now lol cant figure it out, think the valves in the loader control may be stuck from sitting ?
the loader spool controller, i guess that is what its called is stuck on one side so i pulled it appart and the little caps on the end of the levers are a ball of rust and the springs are rusted through so i will be buying a new one. im sure thats the issue it seems to be fighting its self
ok so this valve is junk so can anyone tell me what the lines coming off the tractor are as far as in, out and power beyond for new one they aren't marked at all
ok so fixed the issue after putting on new valve $229 it ended up being that the difference between the lb1914 and the lb1714 is the return line and the power beyond are flip flopped so issue solved
/ kioti 1714 loader issues #7
Glad you got it going!
2017 CHEVROLET SILVERADO 2500HD (A65643)
2017 CHEVROLET...
New/Unused AGROTK Wheel Balancer (A65583)
New/Unused AGROTK...
Auger Cart (A65640)
Auger Cart (A65640)
Stout Brush Grapple XHD84-6 (A66285)
Stout Brush...
2011 Komatsu D61PX (A64126)
2011 Komatsu D61PX...
Deutz D 2011 L03 Engine, 3-Cylinder Diesel (A63689)
Deutz D 2011 L03...
