Rear Blade Kingkutter Rear Blade
/ Kingkutter Rear Blade #1
zuiko
Platinum Member
Minnesota
JD 990 4WD
Anybody have one of these? How do you like it. Any problems?
/ Kingkutter Rear Blade #2
This thread has lots of opinions. There are several others - do a search on "king kutter" and you'll find lots of stuff (if you come up blank on the search remember to change the date range back a few months).
/ Kingkutter Rear Blade #3
I have a HD KK 7' rear blade that I purchased in May... Note, I said HD (Heavy Duty).... I wouldn't purchase the regular one because it looks too flimsy and it didn't pivot for slopes like the HD one. I will state that while I haven't used this blade in the snow yet (the intended use), I have used it for some landscaping with satisfactory results... I believe I paid about $675 for it... nice piece of equipment....
/ Kingkutter Rear Blade #4
~$700 wow that seems high most blades i've seen aren't that much shipped from 100 miles away in the
$400-500 range for HD???
/ Kingkutter Rear Blade #5
Well, given the things I will use it for, I didn't want to buy one of those flimsey ones for $300-400 with questionable support... I'll have to dig up a picture of this for you... it's got more thick reinforced steel than you shake a stick at...
Hey, I'm the kind of guy who is looking for something cheap and good... given I need to plow my 600' driveway, I looked around quite a bit for something that would be rock solid... this little puppy has what it takes to make my list.
Thanks for the info. I didn't know there were two types, not sure which it was that I looked at.
Probably a stupid question, but do you leave the rubber strip on all the time?
/ Kingkutter Rear Blade #7
not sure I know what rubber strip you are referring to??? /forums/images/graemlins/confused.gif.... Do you mean the black metal piece at the bottom of the blade?
/ Kingkutter Rear Blade #8
I find the holes where the pins hold the blade at an angle elongate with long use. Now I don't have this particular brand, but haven't seen anything with hardened steel bushings either. I'm sure the pivot feature is time saving, but for home use wouldn't spend the extra money. /forums/images/graemlins/crazy.gif
/ Kingkutter Rear Blade #9
For $700 i'll buy 2 /forums/images/graemlins/grin.gif though i bought one for $100 an old IH one
MIDWEST Rear Blades RB22-72 6 POSITION with tilt $ 280
MIDWEST Box Blades
*SPECIAL- QTY LIMITED
BB20-60 3/8" SIDES- Red *$ 295
BB20-72 3/8" SIDES- Red *$ 325
BB30-84 1/2" SIDES- Red *$ 495
courtesy prices at http://www.ccmachinery.com/landscape.htm
/ Kingkutter Rear Blade #10
Use to own my own landscaping company and while I may be an IT manager now, I still do lots of landscaping around the homestead... /forums/images/graemlins/laugh.gif.... old habits and uses are hard to break.
2013 Atlas Copco XAS 400 JD7 Portable Air Compressor 125 PSI - Trailer Mounted - Tier 4 (A63689)
2013 Atlas Copco...
2013 Ford Taurus AWD Sedan (A64557)
2013 Ford Taurus...
(3) 11/29-15 Hoosier Dirt Track Tires (1) 29/11-15 American Racer Dirt Track Tire (A64127)
(3) 11/29-15...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
2005 John Deere 7320 (A60462)
2005 John Deere...
Club Car Emergency Cart (A64557)
Club Car Emergency...
