Rear Blade Kingkutter Rear Blade
/ Kingkutter Rear Blade #1
zuiko
Platinum Member
Minnesota
JD 990 4WD
Anybody have one of these? How do you like it. Any problems?
/ Kingkutter Rear Blade #2
This thread has lots of opinions. There are several others - do a search on "king kutter" and you'll find lots of stuff (if you come up blank on the search remember to change the date range back a few months).
/ Kingkutter Rear Blade #3
I have a HD KK 7' rear blade that I purchased in May... Note, I said HD (Heavy Duty).... I wouldn't purchase the regular one because it looks too flimsy and it didn't pivot for slopes like the HD one. I will state that while I haven't used this blade in the snow yet (the intended use), I have used it for some landscaping with satisfactory results... I believe I paid about $675 for it... nice piece of equipment....
/ Kingkutter Rear Blade #4
~$700 wow that seems high most blades i've seen aren't that much shipped from 100 miles away in the
$400-500 range for HD???
/ Kingkutter Rear Blade #5
Well, given the things I will use it for, I didn't want to buy one of those flimsey ones for $300-400 with questionable support... I'll have to dig up a picture of this for you... it's got more thick reinforced steel than you shake a stick at...
Hey, I'm the kind of guy who is looking for something cheap and good... given I need to plow my 600' driveway, I looked around quite a bit for something that would be rock solid... this little puppy has what it takes to make my list.
Thanks for the info. I didn't know there were two types, not sure which it was that I looked at.
Probably a stupid question, but do you leave the rubber strip on all the time?
/ Kingkutter Rear Blade #7
not sure I know what rubber strip you are referring to??? /forums/images/graemlins/confused.gif.... Do you mean the black metal piece at the bottom of the blade?
/ Kingkutter Rear Blade #8
I find the holes where the pins hold the blade at an angle elongate with long use. Now I don't have this particular brand, but haven't seen anything with hardened steel bushings either. I'm sure the pivot feature is time saving, but for home use wouldn't spend the extra money. /forums/images/graemlins/crazy.gif
/ Kingkutter Rear Blade #9
For $700 i'll buy 2 /forums/images/graemlins/grin.gif though i bought one for $100 an old IH one
MIDWEST Rear Blades RB22-72 6 POSITION with tilt $ 280
MIDWEST Box Blades
*SPECIAL- QTY LIMITED
BB20-60 3/8" SIDES- Red *$ 295
BB20-72 3/8" SIDES- Red *$ 325
BB30-84 1/2" SIDES- Red *$ 495
courtesy prices at http://www.ccmachinery.com/landscape.htm
/ Kingkutter Rear Blade #10
Use to own my own landscaping company and while I may be an IT manager now, I still do lots of landscaping around the homestead... /forums/images/graemlins/laugh.gif.... old habits and uses are hard to break.
2018 Regal 29OBX 29ft Boat with 34ft T/A Boat Trailer (A61569)
2018 Regal 29OBX...
2020 GMC AT4 CREW CAB TRUCK (A62130)
2020 GMC AT4 CREW...
2008 Big John 42' Log Trailer (A62613)
2008 Big John 42'...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
Firestone Bolt On Duals 14.8-38 (A65640)
Firestone Bolt On...
New/Unused 16 Gallon Landhonor Vacuum Cleaner (A65583)
New/Unused 16...
