KingKutter 72" Mower fix
/ KingKutter 72" Mower fix #1
PentonKTM
Yanmar YM2000
Hello from a newbie !
I have a relatively new King Kutter 72 " finish mower ( free ! ) that was shoved off into a field and replaced. I am replacing the belt because the main pulley / gearbox housing had become a chipmunk hotel. The manual says to " loosen the belt tension pulley bolt on the L bracket to allow movement " The bolt on the pulley just spins but won't loosen. My question ...... finally ... Does anyone know what is on the bottom of the deck ? Is there a bolt / weld nut that holds/held the tension bracket to the deck ? Any help would be invaluable.
Thanks!
/ KingKutter 72" Mower fix #2
Hi I have a 60 inch landpride finish mower that when I want to clean out the underneath I hook to tractor shorten the toplink as short as it will go and raise the mower which will be a couple feet off the ground and you can see everything you need to see and get to. Hope this helps
Great idea! Thanks
I got it thanks, the " L Bracket" all thread had rusted off so I fired up my welder......... out of wire :-( ...... only thing I could get was some flux core. Welded a piece of allthread to the bracket... all is well .
Thanks for all th help!
2019 John Deere 712C Cornhead (A63111)
2019 John Deere...
2017 Ford Escape 4WD SUV (A61574)
2017 Ford Escape...
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
2017 Ford F-550 4x4 Venturo ET25KX 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
2013 FREIGHTLINER Cascadia (A63689)
2013 FREIGHTLINER...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
