KingKutter 72" Mower fix
/ KingKutter 72" Mower fix #1
PentonKTM
Yanmar YM2000
Hello from a newbie !
I have a relatively new King Kutter 72 " finish mower ( free ! ) that was shoved off into a field and replaced. I am replacing the belt because the main pulley / gearbox housing had become a chipmunk hotel. The manual says to " loosen the belt tension pulley bolt on the L bracket to allow movement " The bolt on the pulley just spins but won't loosen. My question ...... finally ... Does anyone know what is on the bottom of the deck ? Is there a bolt / weld nut that holds/held the tension bracket to the deck ? Any help would be invaluable.
Thanks!
/ KingKutter 72" Mower fix #2
Hi I have a 60 inch landpride finish mower that when I want to clean out the underneath I hook to tractor shorten the toplink as short as it will go and raise the mower which will be a couple feet off the ground and you can see everything you need to see and get to. Hope this helps
Great idea! Thanks
I got it thanks, the " L Bracket" all thread had rusted off so I fired up my welder......... out of wire :-( ...... only thing I could get was some flux core. Welded a piece of allthread to the bracket... all is well .
Thanks for all th help!
2012 Caterpillar CB54 Articulated Vibratory Tandem Smooth Drum Roller (A61572)
2012 Caterpillar...
(INOP) 2012 CHEVROLET TAHOE (A59823)
(INOP) 2012...
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
2019 FREIGHTLINER CASCADIA CA113DC 6X4 T/A DAY CAB TRUCK TRACTOR (A59911)
2019 FREIGHTLINER...
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A64194)
2010 International...
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
