King Kutter XB series
/ King Kutter XB series #1
Tractor Nut
Manitoba, Canada
2007 BX24
I am considering purchasing the King Kutter XB series tiller and box scraper to use with my BX24.
I would appreciate any comments from those of you who have used these attachments.
Thanks
/ King Kutter XB series #2
I just bought a KK II 60 inch tiller. My tractor is rated 23.9 PTO HP and it handled it well. Tiller seems solid. From previous responses about tillers it seems a that the KK II tillers are very well thought of and have worked great for people.
/ King Kutter XB series #3
The KK XB is a different beast than the KK II. I'm not sure if they have anything in common. I've seen a lot of good things said about the KK II series on TBN, and own one myself. It's probably the highest quality of all the KK product. I've seen very little talk about the XB, so I'm not sure of its quality. It definitely is much more lightweight than the KK II (600 lbs vs. 425 lbs)
/ King Kutter XB series #4
The KingKutter II implements are not intended for the subcut class of tractors. i.e. Kubota BX, JD 2210/2305, NH TZ, MF GC etc., they are designed for the cut and above class of tractors.
The XB class implements are specifically designed to work with the subcuts as they are sized to work with the "limited" spread and lift capacities of the 3ph on a siubcut.
Those short rear wheels on a subcut come at a price, they're very good on turf but don't give the subcut much lift for full size Cat1 implements.....
The good thing is that the XB class has gotten good reviews here (do a forum search), the bad thing is they generally cost more than their bigger cousins. I think it has more to do with more of the II class being made and sold than the XB but what do I know, I haven't slept in a Holiday Inn in qute awhile :D
Thanks for the advice. I did a search and came up with some good information.
Looks like they will fit the bill for me and have the best pricing.:)
/ King Kutter XB series #6
Looks good and glad to hear you are happy with it.
Does it cover your wheel tracks properly?
/ King Kutter XB series #8
I just bought a JD 2305 and a 4ft. kk xb box blade and love it. I tried the 5ft but did not have the traction plenty of power and no problem lifting
/ King Kutter XB series #9
Can't comment on the tiller but I'm happy with my XB box blade...
/ King Kutter XB series #10
The tractor is 45'' wide and the tiller is 48'' wide.
it sticks out past the rear tires 1.5 inches on each side.
So yes it covers the wheel tracks properly.
I am looking at 48" for both the tiller and box blade.
Thanks for all your help.
/ King Kutter XB series #13
Thanks
I don't see any need for a box blade if you have a tiller.
http://i283.photobucket.com/albums/kk286/lb59/100_2316.jpg
http://i283.photobucket.com/albums/kk286/lb59/100_2321.jpg
I can do anything with these I could do if I had a box blade.
Adding a box blade to them would just mean another implement to switch around with no added benefit and more money out of my pocket for nothing.
I can back my tiller into a dirt pile and till up fine dirt for landscaping and yard work ~~~ you can't do that with a box blade.
Having a tiller eliminates the need for a box blade and a tooth bar.
I would think the BX24 and a tiller is all you would need.
/ King Kutter XB series #14
LBrown59 said:
5' is to wide for rear mounted attachments on a SubCompact.
I bought the 5ft box blade first becouse I am new to this and the dealer told me 4or5 ft would be fine,
...Adding a box blade to them would just mean another implement to switch around with no added benefit and more money out of my pocket for nothing. I can back my tiller into a dirt pile and till up fine dirt for landscaping and yard work ~~~ you can't do that with a box blade. Having a tiller eliminates the need for a box blade and a tooth bar. I would think the BX24 and a tiller is all you would need.[/QUOTE said:
I don't have the front blade and have about 1000 feet of gravel driveway to maintain - could be a little difficult with only the tiller. From what I have read in other posts the box scraper would come in quite handy. Guess it all depends on what other attachments you already have.
2014 International WorkStar 7500 T/A Leach 2RIII 25Yd Rear Loader Garbage Truck (A61573)
2014 International...
2017 Nissan Altima 4 door (A63689)
2017 Nissan Altima...
Redball 6 Row Hooded Sprayer (A64119)
Redball 6 Row...
2020 John Deere 470G Hydraulic Excavator (A61572)
2020 John Deere...
2023 BOBCAT T770 SKID STEER (A62129)
2023 BOBCAT T770...
2025 Swict 60in. Bucket Skid Steer Attachment (A61572)
2025 Swict 60in...
