Tiller King kutter tillers
   / King kutter tillers #11
it full of gear oil and grease it.well not full of gear oil,what the book says,mine came empty.
Mine too. I recall a decal or wired on notice to that effect.
The only issue I had in setting mine up was deciding how much grease to put in the non powered bearing zerk on the other side. I first added about ten pumps then looked at the diagram and realized there was a big cavity behind the plate so I added ten more. Tilled half an acre and there was no warmth on the cover plate but I got anxious and added another ten anyway. You cannot see any grease come out on the spindle side but there are two seals so I'm not sure that you would until you'd over filled the chamber. Wish they'd give you an idea of what volume to put in.
The gear side is easy following directions and as I recall it takes about a quart or a bit more until it spills out the level hole.
   / King kutter tillers #12
Just measured my tiller. The diameter is 16" from tine-tip to tine-tip.
I was just out in the shop today getting the KK II tiller hooked up to the TC55 and I forgot all about this thread. I was gonna do it (really!). Thanks for getting him the measurements Jim.
Mike
   / King kutter tillers #13
I am pretty sure he is asking about the dia. of the "shaft" the the blade flanges are mounted to. The bigger the dia. is, the more rigid and the less flexing the blades will have. I am sure this will have a infleuance on the life of the unit, especially when you hit that stump!
   / King kutter tillers #14
I had this same question when setting up my tiller. I kept pumping grease into the right side thinking I would eventually see grease come out. Lots of pumps.....no grease. After standing a while.....I got grease to come out the filler zerk. As said...not much for information on greasing this bearing. Can you overpack this bearing???
   / King kutter tillers #15
I think you could overpack which was my concern. If I recall correctly the shaft has two seals on it. You'd have to put a lot of grease in to that bearing compartment to have excess forced out through two seals on the rotating shaft. I ended up putting in about 15-20 pumps as I recall and then quit. I did check the tactile temperature of that bearing cover after tilling about a quarter acre and it was cool so I just left it that way. I now add four or five pumps each time I use it.
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
2014 BMW 320i Sedan (A55758)
2014 BMW 320i...
Ford 655C 2WD Cab Backhoe (A56435)
Ford 655C 2WD Cab...
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
2016 Chevy caprice (A55788)
2016 Chevy caprice...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
