Killing Henbit
   / Killing Henbit #1
geezer32095
St. Augustine,florida
Ford 1510
I am in Fla. have relativly small acereage of pasture & yard grass (6) with 3 horses, & have been spot spraying Henbit for years with 24D & sometimes Glyphosate.. I have never seen it flower & therefore make seeds, however it comes back with the cool weather like clockwork. I just today saw some starting up. Usuauly I don't see it untill Jan/feb. I need to keep it down as if the horses roll in it they get hives & itch. My vet said he saw a horse so covered in hives & itching that it pitched itself over backwards & cracked it's skull & died.:eek::thumbdown: Figured maybe someone here has some ideas besides selling out & moving..
   / Killing Henbit #2
Grazon will knock it out. Follow the label.
It is fairly easy to control but you have to stay on it.
   / Killing Henbit #4
   / Killing Henbit #6
Google 24D and Grazon relative to their lingering effects. Think it's Grazon that'll linger on such that if you collect hay from it or put cuttings from it into mulch, it'll kill any horticulture it comes in contact with. Only use it if you're not ever going to use the hay for much of anything later.
Ralph
   / Killing Henbit
Ralph
Thanks Ralph will do a search on them. It is pasture only, just enough for the horses grazing so that is what I am concerned with. Is it ok for non food animals to graze on. The 24D is, according to the label, not proven to harm grazing animals..
   / Killing Henbit #8
The PDF link I had attached on my last post is the label for Grazon Next. It has all the information you need to decide whether or not that will work for you.
You can get it at Tractor Supply and many other co op / farm stores.
   / Killing Henbit #9
Henbit is a winter annual. It emerges in the fall/winter and blooms and seeds the following spring. Probably why you never see it go to seed plus seeds are very small.
   / Killing Henbit
thanks, I bookmarked the lable site lost of stuff to find there. I won't be able to use the Grazon right now, as it is also a pre-emergent and I have to plant winter rye 1st week of Dec and then wait 6 or 7 weeks for it to withstand the Grazon.
   / Killing Henbit
I usually have it pretty much out of sight by spot spraying it 2 Xs a month all winter. (what we call winter) Enough survives 24D to re seed apparently.
KUBOTA L3410 TRACTOR (A60430)
KUBOTA L3410...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
WOODS 9021 BATWING MOWER (A52707)
WOODS 9021 BATWING...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
2014 Ford Fusion Passenger Car, 2.5L Engine - Only 90,875 Miles (A56438)
2014 Ford Fusion...
