Killing Henbit
   / Killing Henbit #1
geezer32095
Member
St. Augustine,florida
Ford 1510
I am in Fla. have relativly small acereage of pasture & yard grass (6) with 3 horses, & have been spot spraying Henbit for years with 24D & sometimes Glyphosate.. I have never seen it flower & therefore make seeds, however it comes back with the cool weather like clockwork. I just today saw some starting up. Usuauly I don't see it untill Jan/feb. I need to keep it down as if the horses roll in it they get hives & itch. My vet said he saw a horse so covered in hives & itching that it pitched itself over backwards & cracked it's skull & died.:eek::thumbdown: Figured maybe someone here has some ideas besides selling out & moving..
   / Killing Henbit #2
Grazon will knock it out. Follow the label.
It is fairly easy to control but you have to stay on it.
   / Killing Henbit #4
   / Killing Henbit #6
Google 24D and Grazon relative to their lingering effects. Think it's Grazon that'll linger on such that if you collect hay from it or put cuttings from it into mulch, it'll kill any horticulture it comes in contact with. Only use it if you're not ever going to use the hay for much of anything later.
Ralph
   / Killing Henbit
Ralph
Thanks Ralph will do a search on them. It is pasture only, just enough for the horses grazing so that is what I am concerned with. Is it ok for non food animals to graze on. The 24D is, according to the label, not proven to harm grazing animals..
   / Killing Henbit #8
The PDF link I had attached on my last post is the label for Grazon Next. It has all the information you need to decide whether or not that will work for you.
You can get it at Tractor Supply and many other co op / farm stores.
   / Killing Henbit #9
Henbit is a winter annual. It emerges in the fall/winter and blooms and seeds the following spring. Probably why you never see it go to seed plus seeds are very small.
   / Killing Henbit
thanks, I bookmarked the lable site lost of stuff to find there. I won't be able to use the Grazon right now, as it is also a pre-emergent and I have to plant winter rye 1st week of Dec and then wait 6 or 7 weeks for it to withstand the Grazon.
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2019 Ford F-150...
2007 Homemade Pipe Trailer (A55973)
2007 Homemade Pipe...
403 (A52706)
403 (A52706)
2009 Ford E-350 Cargo Van (A56858)
2009 Ford E-350...
Electric Horseless Carriage (A57453)
Electric Horseless...
LOT: Coolant Pressure Tester, Fuel Pressure Tester, Amp Tester (A59076)
LOT: Coolant...
