kill switch?
   / kill switch? #1
2516mo
Bronze Member
Missouri
2010 mahindra 2516 gear
Living in a suburban area, I wanted to see if anyone has installed or had experience with adding a kill switch to disable their tractor.
I will be parking my 2516 outside and wondered if I needed to go the extra step of disabling it.
   / kill switch? #2
Wondering if you could pull the starter relay?
   / kill switch? #3
Simple.
Cut the starter relay wire and insert a hidden switch into that line.
Maybe up under the dash where you can reach it.
On my tractor there is a switch to prevent starting in other than neutral and I simply unplug one of the leads from the switch.
   / kill switch?
Great idea thanks!
   / kill switch? #5
even better .... wire it into a 2 way switch that goes the starter and to a horn instead .... flip it, and any attempt to start it now sounds the horn
   / kill switch? #7
disconnect one wire and add the switch in there (neutral start )
Simple.
Electric Parts Movers (A50121)
Electric Parts...
Fuel Tank (A50121)
Fuel Tank (A50121)
2019 John Deere 3025E (A50120)
2019 John Deere...
Kelly Ryan 2W-14 Bagger (A50774)
Kelly Ryan 2W-14...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2014 Ford F-150...
