Kill a big pine tree
/ Kill a big pine tree #21
Girdling is a known and endorsed forestry technique. Early this year, my forester recommended the technique to get rid of some unwanted trees. Don't be so hard on the OP.
/ Kill a big pine tree #22
I had a very large pine widow maker fall at a 45deg angle in woods last winter. I cut it with saw near base. Dangerous, cut on both sides 20" bar to do it. Last cut I felt protected by another tree up against it.
I cut through but no luck. A few weeks it just slipped down off stump.
Finally used chains and ratchet straps pulling it down and out into pasture with 4x4 truck. There I whacked it safely in 8ft sections, hauled off with tractor.
Scary at times, but done now.
/ Kill a big pine tree #23
In a forest is one thing but I think the OP was killing a tree in his yard and letting it fall on it's own.
/ Kill a big pine tree #24
When it appeared a Tornado might be close last week, Ilost a HUGE LIVE PINE. Probably twenty inches at the base. Just snapped it off close to the base like nothing. A little too big for my chipper, so not sure what to do with it.
The Dead ones are breaking off all the time. They bust a lot of good trees on their way down.
/ Kill a big pine tree #25
Correct, but I think in this case there was more than just girdling performed making it more of a hazard than just a kill.
/ Kill a big pine tree #26
Had a big one next to the Garage and was worried the next severe wind storm would take the top out and wipe out the roof.
Hooked chains and multiple 10k straps to get over a hundred feet to hook to the dozer.
I put a bit of tension on it hinge cut the tree and finally the back cut. Dropped the saw and ran over to the dozer and just slowly pulled until I could see the top start to move and then just pulled a bit faster.
There was a bit of a pucker factor for sure.
/ Kill a big pine tree #28
Wow! One I cut was nowhere close to that. I'm guessing 26"-28" across.
/ Kill a big pine tree #29
Yeah -for a bit of size reference both tractors are wearing 14.9 X 28 R1's and the garage wall is 14'
I didn't need any coffee during or after cutting that tree.
I can't recommend something similar as a DIY job.
Today I would hire out a bonded pro with references.
Not sure what my insurance agent would have said if i had destroyed the garage...
2016 FREIGHTLINER CORONADO 122 SD DAY CAB (A63569)
2016 FREIGHTLINER...
2004 Isuzu NPR 14ft. Box Truck (A61573)
2004 Isuzu NPR...
2008 R&R FLATBED WINCH TRAILER (A63569)
2008 R&R FLATBED...
1994 SHOP MADE ENCLOSED TOOL TRAILER (A63569)
1994 SHOP MADE...
2008 Trail- Eze Tilt Triaxle, 42' Deck/10' Neck (A62679)
2008 Trail- Eze...
2016 Ford Taurus Sedan (A61574)
2016 Ford Taurus...
