Key stop fuse
/ Key stop fuse #1
Cummins67
I have 96 B1700 and i recently purchased a rear mount finish mower for it. I've blown this fuse twice in 2-3 weeks.. could it be related or coincidence? Any ideas are greatly appreciated. Thank you
/ Key stop fuse #2
Check the wiring from the fuse to the stop solenoid, there May be a frayed spot that is occasionally finding a short to ground.
You might also check the time the solenoid stays in the Pull mode, after the key is turned off. If it pulls and doesn't release after 5 seconds or so... your timer is failing... KennyV
2020 Ford Fusion Hybrid Sedan (A64557)
2020 Ford Fusion...
2014 Ford Taurus Sedan (A64557)
2014 Ford Taurus...
HEAVY DUTY MILITARY TENT (A63276)
HEAVY DUTY...
2022 EZ-GO ELITE...
2013 Toro Groundsmaster 3280D 72in. Commercial Riding Mower (A64194)
2013 Toro...
2008 DRESSTA TD-15M EXTRA CRAWLER DOZER (A65053)
2008 DRESSTA...
