keeping tractor from being stolen
/ keeping tractor from being stolen #21
Gfranklin:
Sorry to post this here but I busted out laughing when I read your post, we once had a rooster and you could not turn you back on him even for a second. he was only a banny (spl*) so he was little but mean as the dickins called him Brooster ....brooster the rooster...lol
Whiskey
/ keeping tractor from being stolen #22
Who picks locks anyway? I've never heard from anyone who had a lock picked - it's almost always force - cut the lock, cut the cable, break the door, winch it up on a flatbed, sledge hammer to the hinges... you get the idea.
Edited to add - the folks who stole my saw evidently are 1) local, 2) knew where it was 3) knew when I wasn't home. I wouldn't rely on secrets for people like that - they see you do the rigamarole when you start it up
/ keeping tractor from being stolen #23
Thumbtrap-
You are 100% right. Nobody picks locks anymore. But everytime someone has something stolen from a barn or house or car they forgot to lock, they always claim the lock was picked. The insurance company won't buy it, particularly on a high value item like a tractor.
There have to be signs of forced entry so the cops can write it down in the report.
/ keeping tractor from being stolen #24
<font color=red>That is a great idea. Won't work for Kubota, though. The fuel solenoid on a Kubota pulls in electrically when the key is shut off. It stays pulled in for less than 10 seconds, then releases. Kubota owners, that's the click
<font color=black>I havn't actually pulled mine apart.. but it must be a pull in solenoid system. I've notice dthat when my battery was weak, the tractor would turn over but not start.. and i could hear a solenoid clicking under the cowling.. but it wasn't the starter solenoid. I figured it takes a bit to keep it energized to stay in. I imagine there is a 3 or 5 amp fues in my panel that covers that but havn't ever looked.
On my old yanmar, I have a set of battery dissconnects that are made right into the battery connector.. just twist a nut and it makes contact.. but looks connected and 'normal' at a casual glance.
As for my old 8n.... unless they know the 'dance and secret handshake + corect series of throttle choke combinations... they won't get it started anyway /w3tcompact/icons/eyes.gif/w3tcompact/icons/smile.gif '
Soundguy
/ keeping tractor from being stolen #25
You are right about no one ever picking a lock. It is for this very reason that I am willing to actually "break" the key off in the lock on my toolshed. I figure it will never be that closely examined and induces them to start with brute force right off the bat. It sure does make it convienent for me though.
That rigamarole I described earlier was mostly in jest with the point being that a couple of them done together will increase their "time on the job" which tends to elevate their nervousness. I am supposing that for the typical burglar there is a proportional relationship between the burglary duration and the desire to leave. Anything to slow them down including the easy and obvious stuff.
I would think that your odds decrease considerably once they get the engine running.
Greg
/ keeping tractor from being stolen #26
<font color=blue> I am willing to actually "break" the key off in the lock on my toolshed </font color=blue>
How would you get into your toolshed?
/ keeping tractor from being stolen #27
If it's just a matter of not having one more key - you can get padlocks keyed to quickset and schlage key blanks and have them keyed to your house key. No tricks requiring obscurity for protection, no extra keys.
/ keeping tractor from being stolen #28
We hunted on a 300acre farm that had a long drive
and a cable and pad lock across at the road.
The owner said the combination was still on
back of lock.
No one ever looked there I guess and he never had
people drive back.
/ keeping tractor from being stolen #29
BWS,
I bought a good quality transport chain and a 4 wheel
combination lock. The lock allows you to set the combination
so I used these things all over the place. Gate, storage bins
at work, tractor, etc. I loop the chain around the FEL and/or
the axle and then around a big tree.
Yes, someone could cut the tree down or cut the lock/chain
but it requires them to bring in the equipment to do so. I
don't have a barn or a house on the property so I lock up the
gate, hide the tractor, and lock it up.
First a thief has to know the tractor is on the property. Very
few people know this in the first place. Then they have to
know if I leave it. Then they have to find it on 50+ acres.
Once they find it they have to get through the chain/lock.
Then they have to find a way to start the tractor to move
it. I set up the tractor like others to make it hard to start so
you really have to be lucky, persistent or know the equipment
to get it started.
Can all of the above happen? Yes but it danged hard. I can
see other equipment that would easier to steal than mine!
Actually I'm more worried about the teenagers finding the
equipment and vandalizing it than I am with theft. In either
case my insurance should cover any problems.
Good Luck!
Dan McCarty
/ keeping tractor from being stolen #30
I don' technically break the key. I cut it off clean immediately past the last pin location and them insert that part of the key back into the lock as if it had been broken off (in essence, the key is never taken out from then on. The important part of the key is now permanently in the lock). Keeping the cut off portion of the key as short as possible makes it unnoticeable and provides enough depth for later opening the lock with something else. From then on I take whatever is handy such as the tip of another key, pocket knife or small screwdriver and partially insert it in the blocked keyhole and turn. Now I never need a real key to keep up with.
Greg
/ keeping tractor from being stolen #31
Speaking of illusion, on the news last night was a blurb about how most thermostats in offices are not hooked up. They are there to instill a sense of employee control and comfort. My cubicle is beside the thermostat and I have seen the other office workers come by all day long and adjust that thermostat and then feel fine. A long time ago, due to fatigue, I quit telling them that so and so had just adjusted it. It makes me laugh now because I always thought the heating system was being adjusted way too much for it to work. Now I know the real story.
I knew a guy once that had two pieces of chain hooked together with a lock and he would throw it around anything if he was going to leave it unattended. He never locked the loose ends. He would walk up to it, insert his imaginary key for the benefit of an viewers, and "unlock" it.
Greg
/ keeping tractor from being stolen #32
<font color=blue> put a pc of wood under seat so switch
is open.</font color=blue>
I'm amazed at how easy my JD4300 is to start. You can have it sitting there with the brakes off, the gears in neutral, no weight on the seat, and just turn the key and it fires up. And I gather the keys are not all that unique.. there are only a few, and if you have the right one, you're set to go. Maybe I should thing more or insurance than of prevention of theft?
/ keeping tractor from being stolen #33
Here's a Large Case-IH available for the taking at the Pennsylvania AG Progress Days - How many keys are left in the equipment at these shows? Maybe camera's and parking equipment close together will stop theft.
/ keeping tractor from being stolen #34
Speaking of illusion and our imagination---just let you'uns let your imaginations run on this one--I posted it once before on another thread. Black lab--pit bull-- blue heeler cross.
Whaddya think????
/ keeping tractor from being stolen #35
That's got to be one ugly dog. :)
/ keeping tractor from being stolen #36
Right on--- but NOOOOOOOOBODY bothers my tractor, either!!!!!!/w3tcompact/icons/smile.gif
/ keeping tractor from being stolen #37
I've got one of those sign that shows a picture of a dog then says: I can make it to the fence in a second and a half...can you?
Dogs are great deterants for the casual opportunity thief.
For instance, our neighborhood was hit a few months ago two nights in a row by ( presumable kids or teens ), and I for some dum reason lef the front gat open to the area around the house, so they got a set of PA speakers from my wifes van she left the back unlocked. Luckilly the dogs were loose in the back pasture cause if they would have gotten into the barn, there was much more stuff to get.
All in all I guess I was lucky.. only a couple hundered in theft.. and no damage.. some of the neighbors got hit a bit more... except the guy that REMEMBERED to close his front gate so his rotties had the complete run of his property.
Soundguy
/ keeping tractor from being stolen #39
A little off topic, but a funny story just the same. Recently we had a large ice storm that knock power out in some places for a week. My mother-in-law told this story about a neighbor.
One evening, he's sitting in his living room watching tv in a bathrobe and slippers with the generator running just outside his garage. He notices his lights and tv blink, then go off, but he can still hear the generator running. So he gets up to investigate and when he goes out to his garage he sees his generator, still running, going down the road in the back of a pickup truck/w3tcompact/icons/shocked.gif. But because he wasn't dressed he couldn't go after them.
I think the moral of this story is thieves mostly steal something based on opportunity and not so much as careful planning.
gary
2008 International 4300 Altec AT40C 34ft. Bucket Truck (A64194)
2008 International...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2018 Freightliner Cascadia 125 Truck T/A Sleeper Cab Truck Tractor (A64194)
2018 Freightliner...
2020 KENWORTH T880 DUMP TRUCK (A65054)
2020 KENWORTH T880...
LOOK! (A65640)
LOOK! (A65640)
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
