keep your quick connects super clean
/ keep your quick connects super clean #1
spechols
Central, PA
Power Trac PT425
Based on another thread "Reason #319 why you want to keep your quick connects super clean. I now use brake cleaner to clean out the quick connects before coupling them. (Thanks to Chet Larson)"
What are your methods for keeping the quick connects super clean?
For example - I use a spray of WD40 but I have never asked anyone. So....
What are your best methods?
Thanks
/ keep your quick connects super clean #2
Cleaner, dust caps, keep the attachment ones connected together when not in use. Don't bang on them when stuck.
/ keep your quick connects super clean #3
I've only recently had any quick connects so all of mine are new. I sprayed them with a mix of lanolin and naphtha. The naphtha evaporates and leaves a light coat of lanoline. Lanoline is a well known treatment to prevent rust. Most commercial antirust sprays use it. When they're not in use, I keep them covered with vinyl rubber cups that came with the fittings. That's both male and female ends. I buy brake cleaner by the case and use that everywhere in the shop for spot cleaning. If I'm washing down the tractor, I'll use a degreaser where needed before pressure washing then follow that with the lanolin treatment.
As far as WD-40, I use it for an occasional wash down. I buy it by the gallon and use it for machining aluminum. It works good for that.
/ keep your quick connects super clean #4
To be honest, I've never used more than a rag to clean off the quick connects. I do try and put the caps on the main PTO connectors on the FEL arms when not in use. The AUX PTO connectors are always connected, so no chance of dirt getting in there. And I connect the mower and brush cutter hoses together when not in use. The only connectors that aren't connected together when not in use are the two hoses on the power angle snow blade. They are the same *** and cannot be connected together.
/ keep your quick connects super clean #5
I sometimes wonder if all the hose changes between the quick attach and the implement, is one reason for the 50 hour hyd filter change. Most people or employees just reconnect them (not good).
/ keep your quick connects super clean #6
There's a lot of sand in the clay soil here. I'm always careful to clean around drain plugs, filters, fuel/oil connections and such for all my equipment--Including the shop. I guess I just do it subconsciously. I had a nightmare when I first moved here of pulling the oil drain plug and sand pouring out. :eek:
/ keep your quick connects super clean #7
I keep caps on when not in use, and couple male/female ends on the attachments.
I do use the brake cleaner on the inside of the fittings, as it seems as if dust still gets in around the edges. I blow the rim of the quick connect fittings out with compressed air whenever I clean the tractor.
All the best,
Peter
/ keep your quick connects super clean #8
I just wipe them down with a rag and try to keep the caps on. But mine leak, so don't listen to me. :laughing:
/ keep your quick connects super clean #9
Rag, air compressor if close by and rag. I have caps for all the ends, including the blade, rough cut mower gets connected together. I do put lanolin based grease on the actuator rams when i put the PT away, after cleaning things off. Also on the blade, clean and lanolin grease the ram.
/ keep your quick connects super clean #11
I wipe the big chunks off with a glove or rag and keep going. I did swap fittings early on so implement hoses can be connected together when not in use, and there's no question of which way to connect. Probably not the best way to do it, but after 16 years it all still works pretty well.
2018 FORD TRANSIT KUV (A67714)
2018 FORD TRANSIT...
2007 STERLING LT7500 SERIES CRANE TRUCK (A67714)
2007 STERLING...
2027 . . (A67714)
2027 . . (A67714)
1998 CHEVROLET C7500 (INOPERABLE) (A67714)
1998 CHEVROLET...
3097 (A63117)
3097 (A63117)
2000 Hino (A64194)
2000 Hino (A64194)
