Keep having to sign in
   / Keep having to sign in #1
L4400
Haymarket, Virginia
See signature
Hello,
Every time I exit TBN, and reenter, I keep having to sign back on. I thought maybe it's something with my computer, but it doesn't happen with other web sites I visit. I have only been having this problem today. Thanks for any help you can provide.
   / Keep having to sign in #2
Make sure you check off the "Remember Me?" button next to the log on screen. Also, check your cookie settings and make sure the "www.tractorbynet.com" domain is not in the blocked list.
Thanks for the tips. I have been checking the "Remember me" box. I don't know how to check the cookie settings, I'm not real sharp with computers. Is this easy to do or is this something I need to have someone show me in person? Thanks again.
   / Keep having to sign in #4
Assuming you are using Internet Explorer (Firefox is similar but not identical):
Go to the tools menu, choose internet options
Go to the Privacy Tab
Click on the button that says "Sites"
If TractorbyNet.com is in the list, make sure it says "Always Allow" not "Always Block"
Yes I am using Internet Explorer. I tried that and had it on "always allow". I also just noticed that on my home page, which is MSN, that it doesn't remember my local weather also. When I go back to MSN, I have to put in my zip code each time to get my local forecast. I guess something's wrong with my computer and not just my access to this site.
   / Keep having to sign in #6
As for the MSN page, You might try setting up "My MSN" It's in the upper left corner. I also had to keep logging in here until someone told me to NOT sign off. Just close with the X in top right. That did it for me. I also save it in FAVORITES for quick log in. Good luck
   / Keep having to sign in #7
Thanks, Scott. That taught me something new, too.
   / Keep having to sign in #8
Hadn't thought of the signout issue .... if you don't want to have to sign in, don't sign out. Good catch. If you're already doing this part right, one other thing to check:
Internet Exlporer
Tools Menu
Internet Options
Privacy Tab
Advanced button
Is the override button checked? If so, what options are selected? If "block" is checked, that would also cause the problem.
I don't know what's going on, but it's working fine today.:confused:
   / Keep having to sign in #10
Here's an odd one.. i was just browsing a sub.. read a message, and then went back to the main page of the sub.. .. when i got there.. i was logged out and had to log back in.. ? what happened?
soundguy
2021 VOLVO A40G (A52472)
2021 VOLVO A40G...
2012 CASE IH 1230 LOT NUMBER 186 (A53084)
2012 CASE IH 1230...
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A52576)
2014 HINO 338 26FT...
2010 MACK PINNACLE (A52472)
2010 MACK PINNACLE...
NEW  Ripper Shank (A53002)
NEW Ripper Shank...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXATXDH646719 (A51572)
2013 Dodge Charger...
