KB 2365 Backhoe Attacment
/ KB 2365 Backhoe Attacment #1
gilbertmsg
Disputanta, VA
2007 Kioti CK20
Going to look at 2004 KB 2365 for my CK 20. It's on craiglist and would like to know if $2000.00 is a good value if in good shape. Comes with 18" bucket.
Thanks!!
Eddie
/ KB 2365 Backhoe Attacment #2
(Going to look at 2004 KB 2365 for my CK 20. It's on craiglist and would like to know if $2000.00 is a good value if in good shape.) Eddie
If it is in any kind of halfway decent shape than in my opinion the answer is "yes". A new Kioti KB 2465 costs about $6500.
When you look at this hoe, you might want to check the wear on that bottom pin the boom swings on for excessive slop/wear. I don't have any idea what it costs to replace that pin but that might be a good indicator of just how much use the hoe has had.
rimshot
/ KB 2365 Backhoe Attacment #3
Also check the valves. The KB2365 had some issues with the control valves which was repairable but cost a few bucks to fix.
I had a 2365 on my CK20 and it was a fine backhoe. No problems at all.
Check bushings/pins for grease etc. I'd even try to grease it fully with my own gun just to make sure all the zerks were operating.
The KB2365 has one safety issue I discovered: don't ever flip the seat up while the tractor is running. The rear of the seat hits the BH joysticks and as I recall (don't ask how I know), it will lift the rear of the tractor right off the ground.
213078 (A64276)
213078 (A64276)
2021 JCB 35Z-1 Mini Excavator (A61572)
2021 JCB 35Z-1...
2019 Terra Gator TG8400C Spreader (A63111)
2019 Terra Gator...
Hardee Tiger SH-360-CO (A64119)
Hardee Tiger...
UNUSED WOLVERINE 6' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2017 Freightliner M2 106 Auto Crane HC10 5 Ton Crane Service Truck (A61573)
2017 Freightliner...
