KB 2365 Backhoe Attacment
   / KB 2365 Backhoe Attacment #1
gilbertmsg
Disputanta, VA
2007 Kioti CK20
Going to look at 2004 KB 2365 for my CK 20. It's on craiglist and would like to know if $2000.00 is a good value if in good shape. Comes with 18" bucket.
Thanks!!
Eddie
   / KB 2365 Backhoe Attacment #2
(Going to look at 2004 KB 2365 for my CK 20. It's on craiglist and would like to know if $2000.00 is a good value if in good shape.) Eddie
If it is in any kind of halfway decent shape than in my opinion the answer is "yes". A new Kioti KB 2465 costs about $6500.
When you look at this hoe, you might want to check the wear on that bottom pin the boom swings on for excessive slop/wear. I don't have any idea what it costs to replace that pin but that might be a good indicator of just how much use the hoe has had.
rimshot
   / KB 2365 Backhoe Attacment #3
Also check the valves. The KB2365 had some issues with the control valves which was repairable but cost a few bucks to fix.
I had a 2365 on my CK20 and it was a fine backhoe. No problems at all.
Check bushings/pins for grease etc. I'd even try to grease it fully with my own gun just to make sure all the zerks were operating.
The KB2365 has one safety issue I discovered: don't ever flip the seat up while the tractor is running. The rear of the seat hits the BH joysticks and as I recall (don't ask how I know), it will lift the rear of the tractor right off the ground.
2020 Mathieu MC210 Azura Flex Street Sweeper (A51691)
2020 Mathieu MC210...
2008 Jordair Marines-320-DH Trailer Mounted Air Compressor (A51691)
2008 Jordair...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
28013 (A50322)
28013 (A50322)
2016 KENWORTH T660 SLEEPER (A52472)
2016 KENWORTH T660...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
